Fire Escape Painting - Products Process
Old 05-07-2008, 09:23 PM   #1
plazaman's Avatar
Rewards Points: 1,202
We've painted many fire ecapes & rails before, but usually a quick pass with wire brush and SW DTM or Industrial Enamel
Client was thinking the possibilty of sandblasting the 2 fire escapes, but i advised that it will probably cost too much for setup & containment. Its an old time mansion, not sure what they do there, some kind of service, anyways, i know the type of work they are asking for should be top notch.
There are areas of peeling paint and rust, not entirely, but a couple of spots, maybe 10% of the total fire escape. I told her we could mechanically remove the rust spots prime & paint.
Would 1 of those wire wheels be able to feather the paint nicely? I dont want to areas scraped to be shown.
What products do you suggest I use? Something from the SW line, prime & topcoat.
Thanks
Rich
plazaman is online now
Old 05-08-2008, 05:58 AM   #2
Steve Richards's Avatar
Trade: hack painting
Re: Fire Escape Painting - Products Process
You might consider using an angle grinder with a flap disc. The flaps are made of sandpaper, so it'll feather a lot better than a wire wheel.
If you don't own one..you can purchase a cheapo angle grinder for (way) under $100 at any box store. I haven't had much luck finding the discs, so I get them on the internet.
Far as product...you're going to need a primer suitable for bare metal, as this method will remove paint and rust, and leave nice shiny metal.
and if you don't own a decent pair of safety glasses...please buy some!
BTW.. If someone, for some reason, painted it before w/latex, forget it.
Topcoat: not familiar w/SW products...but I'm sure they have some kinda industrial/exterior enamel
Steve Richards is offline
Old 05-08-2008, 06:44 AM   #3
Any Season's Avatar
Rewards Points: 250
Plaza,
I did one of those but it was spiral and it was peeling quite a bit last fall. I wire wheeled it, then used a product called 'Hammerite'. This stuff was the balls and it required no priming. Also it was so thick that it leveled any areas that we scraped and left it with a nice semi-gloss sheen. Awesome stuff. Like $50/gallon but you save money on additional coats and prep. Here's a product overview on it:
"Hammerite Rust Cap Paint
Hammerite is a long-lasting quick dry enamel paint that lets you paint right over rust, with no primer needed. Its rust-encapsulating formula and rust-preventive coating are designed to provide both interior and exterior long-lasting metal protection. Hammerite provides a decorative finish that resists corrosion and the weather. This versatile paint can be used for a variety of applications - from covering rust to painting lawn furniture, crafts, machinery, metal wagons and more. It's terrific on iron, steel and most metal surfaces. Hammerite Rust Cap paint dries to the touch in 30 minute. Recoats should be applied within 4 hours, before curing begins.
Hammerite also offers galvanized and aluminum primer for use on metal surfaces in conjunction with rust encapsulating paint."
Any Season is offline
Old 05-08-2008, 06:57 AM   #4
I've never tried the Hammerite...do you know...can it be custom mixed, or does it only come in certain colors?
Old 05-08-2008, 07:15 AM   #5
nevermind
"HAMMERITE Rust Cap paint is available in 11 smooth finish and 11 hammered finish colors – there’s sure to be one that’s perfect for your next project."
Old 05-08-2008, 07:56 PM   #6
plazaman's Avatar
Originally Posted by Steve Richards View Post
nevermind
i do not want to remove all the paint, only scrape the loose stuff and feather nicely, i will be priming the entire escape. Will this feather nicely? Im not sure if that hammerrite stuff is available in the US, i check the site, it seems to be a euro product.
Old 05-10-2008, 08:30 AM   #7
A grinder w/a flap disc will feather out the old paint nicely..as long it's not latex.
If you're not planning to remove ALL the paint, then don't use the grinder on ALL the railings.
Old 05-10-2008, 04:27 PM   #8
Any Season's Avatar
Rewards Points: 250
Plaza,
I bought it at one of the local BM stores. It is perfect for what you are doing you can basically do a light scrape/wire brush, then repaint and it will level nicely.
Old 05-10-2008, 04:32 PM   #9
Any Season's Avatar
Rewards Points: 250
http://www.amazon.com/Paint-Hammerit...0455079&sr=8-2
This is about what I paid at my local store. Good luck man.
Old 05-10-2008, 09:49 PM   #10
plazaman's Avatar
sounds good. Lets just hope i get the job. Even if i dont, its good that i know the proper prep and products for the future. thanks
Old 05-27-2008, 04:15 PM   #11
dincao's Avatar
Trade: painter
Rewards Points: 25
Anyseason do you now if the top coat is oil or acrylic, the primer says its acrylic??wondering if it voc compliant in Ny i have 7 fire escapes completly rusted and this product would work great for the HO request!!
dincao is offline
Old 05-27-2008, 04:24 PM   #12
plazaman's Avatar
what kind of prep are you planning on doing to them?
Old 05-27-2008, 04:37 PM   #13
dincao's Avatar
Trade: painter
Rewards Points: 25
they are complete rust, not really flaking or peeling but just wire brush and if i can find something like hammerite it would be great... These are rental properties Ho knows what should be done but does not want to pay for the way i would typically prep, so my options are limited!!!
dincao is offline
Old 05-30-2008, 07:17 PM   #14
dincao's Avatar
Trade: painter
Rewards Points: 25
Still waiting to here about this product from all the guys that said ITS GREAT!!!!! HAMMERITE THAT IS!!!!!!!!!
dincao is offline
Old 05-30-2008, 08:52 PM   #15
plazaman's Avatar
Yep, i know they type of work they are looking for.
Fire cleanup Loghome54 HVAC 0 03-12-2008 11:02 AM
Fire Escape Ladder / Electrical Pricing dougchips General Discussion 65 11-28-2007 05:01 AM
Concrete fire pit ronald owen jr Masonry 14 08-07-2007 09:24 PM
Where's my thread? (Politics anyone?) AAPaint Off Topic (Non Trade) 175 08-16-2005 12:45 AM
Help with my painting process + Airless Spray. Phouvieng Painting & Finish Work 10 07-09-2005 12:58 AM
