Trade: residential remodeling
Finished Spraying The Ceiling, How About The Trim
well,,, i sprayed all the ceilings with a 517 tip and worked out great, next i want to spray the doors and trim. i bought a 417 tip for that. was i correct or what??? i hope so, now i have a 513,515,517,619, and a 417 tip. i would of used the 619 tip on the ceiling but it's too much of a wide fan for me just yet. i still need more practice.
Trade: Painting Contractor
Re: Finished Spraying The Ceiling, How About The Trim
ffor the doors i would use a 311 & for the jams i would use a 211
Sean |
Trade: Painter
Agree with above, the 17 size orifice is too big for finish paint. Most guys I know use a 10 or 12 opening fine finish tip.
Trade: painting
211 trim
411 doors |
Trade: painting contractor
I agree with posts above but have also used 213,313,215, and 315. monitor the pressure at your rig as well also helps. usually dont need full pressure, but you can tell if you are getting a nice fan. If you are just learning, the smaller the tip the easier the learning curve.
Gary |
can i possibly use a 513 on the doors??? or should i just buy the 211 and 411. the reason i'm asking is i having buying tips like crazy and it's not cheap.. 20 bucks at sw. can i get some more info please.
your guys are great!!!! thanks |
Trade: painting
ten inch fan is pretty big but would work fine. SPray away!
#8 | |
My custom title
5 will work out ok, just stand back and don't get too close or you'll glob the paint.... practice on a board and spray away. I use a 517 on ceilings, doors, trim... but i've also got about 30 years on ya.
Benn Quote:
Should of added tips into the material part of the job. It is all overhead. Quality is never cheap, not with you or your material
Sean |
well guys...... i bought a 214 and a 314. man, i FLEW thru the doors and trim without one run!!! holy cow,,,i've been a brush and roll man for 22yrs and never tried spraying. the new tips are the fine finish tips with the green guard. $27 each, not bad for the time saved.
Trade: carpentry
ok guys, i have been doing a little painting lately and the spraying trim sounds great, i don't remember what thread it was but someone mentioned using a cup sprayer for trim. do you guys tape off the ceilings? how do you keep overspray from getting on the ceiling? and is this possible to do on repaints. i think it would be much easier to cut and roll the walls than to cut the trim after the walls are rolled, thanks for your help. funny how life works, started out thinking i was going to be the worlds greatest trim carpenter but after people have seen a couple of rooms ive painted, ive been getting calls to paint.
#12 | |
My custom title
I wouldn't suggest a cup sprayer for trim.. just furniture grade stuff... like bookcases or nice wainscot. I also wouldn't think too hard on a sprayer for interior repaints.
Benn Quote:
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Questions about interior trim spraying | Jerdog44 | Painting & Finish Work | 13 | 08-23-2007 04:39 PM |
| tip sizes for trim spraying | remodeling joe | Painting & Finish Work | 27 | 03-11-2007 08:21 PM |
| spraying Trim | Workaholic | Painting & Finish Work | 7 | 03-08-2007 12:26 AM |
| hvlp vs. airless for spraying trim | Traditions | Painting & Finish Work | 13 | 08-25-2006 08:49 AM |
