Exterior Trim: Satin Or Semi Gloss
Old 07-15-2009, 07:00 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 8,790
got talked into using satin finish on exterior trim. After painting a dozen or so boards, thinking I should have used the semi gloss. Brand is C2 and the satin is self priming, but I'm going over oil based primer anyway. Thoughts?
Morning Wood is offline
Old 07-15-2009, 10:42 PM   #2
Workaholic's Avatar
Trade: Painting Contractor
Re: Exterior Trim: Satin Or Semi Gloss
I run a lot of semi- unless a lighter sheen is desired.
Of course the ICI Dulux semi is really more like a satin.
Sean
Workaholic is offline
Old 07-15-2009, 10:50 PM   #3
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
Rewards Points: 1,008
I use satin on exteriors by default. I will paint a house flat if they insist but I like satin, and yes satin for trim. I use Dulux Fortis exterior paint.
nEighter is offline
Old 07-20-2009, 12:51 AM   #4
jmda
jmda's Avatar
Trade: Painter
Depends. Use mostly low lustre (satin) in BM Aura or Moorgard, though I have used semigloss on windows and trim did so recently.
jmda is offline
Old 07-20-2009, 03:46 AM   #5
Wolfgang's Avatar
Trade: Painting & Remodeling
Rewards Points: 502
Here everything goes mostly satin on the trim, semi gloss very rarely.
Wolfgang is offline
Old 07-20-2009, 04:59 AM   #6
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Here,where????? America, Australia,Amsterdam,Austria, Antigua, Antarctica,Albania,Alabama,Arkansas?:lau ghing:
chris n is offline
Old 07-25-2009, 11:29 PM   #7
410tip's Avatar
Trade: Painting, Residential/light commercial
Rewards Points: 25
Seattle..pretty standard to go flat on the body, satin on the trim. I'd say at least 80 percent of my repaint jobs are previously this way.
410tip is offline
Gloss, semi gloss or satin, anything to think about other than the shine? Texwing Flooring 26 07-19-2017 11:20 PM
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 07:29 PM
satin or semi gloss??? tyler durden Painting & Finish Work 6 07-14-2008 07:59 PM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 05:38 PM
Semi gloss on walls?!?!what do you think?? lornmastro Painting & Finish Work 21 02-16-2007 09:52 PM
