Exterior Paint From SW, Flat Or Satin
Old 04-05-2007, 11:54 PM   #1
joseph
Guest
joseph's Avatar
Posts: n/a
Hi you guys, I haven't really used much paint for exterior siding from SW, but now a client has requested the paint to be bought there, and I am not very familiar with the sheens there, because I use, "low sheen" from kelly moore, which I like, but SW has flat then satin, no low sheen. So my question is; is satin from SW to shinny for siding, or is it ok ? and if ok, what about the trim, gloos? Because I really like to put some sheen to the siding, but the lowest posssible. Bottom line fellows, What do you recommend the most from SW, flat or satin, for siding?
Thanks!
Old 04-06-2007, 12:01 AM   #2
bgpainter
Guest
bgpainter's Avatar
Posts: n/a
Re: Exterior Paint From SW, Flat Or Satin
satin is just like BM low luster
Old 04-06-2007, 12:38 PM   #3
Joewho
Guest
Joewho's Avatar
Posts: n/a
Go with the satin. It's not very shiny.
SW paints go, satin, eggshell, semi-gloss, gloss and high-gloss.
The whole SW line of sheens isn't as shiny as some of the others.
Flat Poly to a satin poly lornmastro Painting & Finish Work 10 04-22-2007 07:00 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
flat over satin googen9 Painting & Finish Work 3 05-13-2006 08:17 PM
