Exterior House Paint
Old 08-11-2009, 11:01 AM   #1
UniqueInteriors's Avatar
Trade: Painter
I have read mixed reviews on what a good brand of exterior paint is? I am painting a house that is currently white and most likely will be painted white again, planning on power washing loose paint and debris. Then prime the bare spots and go over entire house with a coat of paint. Was thinking of using a primer/paint in one, what is a good brand to go with and should I paint 1 coat prime/paint in one or two coats regular paint and prime bare spots? The siding is wide wood clap boards. Thanks
UniqueInteriors is offline
Old 08-11-2009, 11:25 AM   #2
NAV's Avatar
Trade: commercial building restoration
Re: Exterior House Paint
seriously? you are a painter and you don't know how to paint a wood exterior?
NAV is offline
Old 08-11-2009, 11:26 AM   #3
Trailer park boy
shanekw1's Avatar
shanekw1 is offline
Old 08-11-2009, 11:35 AM   #4
Trade: Painter
NAV,
Yes I am a painter, only have done a few exterior jobs though and looking for some advice. You do not have to be a bastard, do not waste my time by replying. Thanks
The Following User Says Thank You to UniqueInteriors For This Useful Post:
HusqyPro (08-12-2009)
Old 08-11-2009, 11:37 AM   #5
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Behr is the best
ModernStyle is offline
Old 08-11-2009, 12:17 PM   #6
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
You got a mean streak in ya Modern.
www.draftinginoc.com
ScipioAfricanus is offline
Old 08-11-2009, 02:29 PM   #7
Store Owner
NCPaint1's Avatar
Trade: Paint Store Owner
What type of wood?
Is the peeling between coats or down to bare wood?
Is the surface chalky?
1. Powerwash, use some sort of cleaner, be it a housewash or my TSP, bleach & water mix.
2. Scrape and sand peeling areas so theres no loose paint.
3. Depending on the paint you use, may or may not require a primer, but the product itself to be used as a primer.....before I make a reccomendation refer to my first 2 questions.
4. Paint ( whatever you choose ) I prefer Benjamin Moore, depending on the finish, either the Moorlife ( Flat ) or the Moorgard ( low lustre )
www.northcromwellpaint.com Benjamin Moore Paint, PPG Paint, TWP Stains, Sikkens Wood Finishes, Airless Sales, Service, and Rental
NCPaint1 is offline
Old 08-11-2009, 05:33 PM   #8
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Originally Posted by UniqueInteriors View Post
NAV,
vandyandsons is offline
Old 08-11-2009, 08:33 PM   #9
Wolfgang's Avatar
Trade: Painting & Remodeling
So there!
Wolfgang is offline
Old 08-11-2009, 09:42 PM   #10
Trade: Painter
Its not cedar, I am guessing typical hardwood like oak..there is some peeling but not everywhere. Going with a seperate primer and a Bejamin Moore exterior paint. What is a good solution to go with just to get layer of dirt off and remove the loose paint?
Old 08-11-2009, 09:47 PM   #11
dan-o's Avatar
Trade: residential painting & carpentry
Wash it with the tears of the last homeowner you disappointed.
dan-o is offline
The Following 5 Users Say Thank You to dan-o For This Useful Post:
capital city (08-12-2009), HusqyPro (08-12-2009), Metro M & L (08-11-2009), ModernStyle (08-11-2009), Tom Struble (08-13-2009)
Old 08-11-2009, 09:54 PM   #12
Trade: Painter
You are a really funny person, go fall in a whole. I thought this was a place for discussion and reference not f-ing off.
Thanks for your words of wisdom you must do well with painting as a career.
Old 08-11-2009, 10:18 PM   #13
This is what I would use, It works hard so you dont have to.
+ YouTube Video
Old 08-12-2009, 05:30 AM   #14
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
OAK?
chris n is offline
Old 08-12-2009, 09:45 AM   #15
Store Owner
NCPaint1's Avatar
Wash, with 4oz TSP + 1qt bleach and 1 gal water mix. Scrape/sand loose peeling areas, prime with Zinnser Peel Stop on the bad areas ( not the whole house ) and then paint.
NCPaint1 is offline
Old 08-12-2009, 10:27 AM   #16
We really must have pix
of oak siding!
neolitic is offline
Old 08-12-2009, 03:59 PM   #17
capital city's Avatar
Trade: painting
NAV,
If you are a painter then you should ask the paint rep that you buy all of your interior paint from on what exterior paint he would spec for the job. Whenever I stray from my normal routine I call my SW store manager and tell him what is up and what would he recommend and stand behind. We are here to help each other out but we do not help out hacks or homeowners.
capital city is offline
Old 08-12-2009, 04:16 PM   #18
Workaholic's Avatar
Trade: Painting Contractor
You should go here for the answers you seek
Sean
Workaholic is offline
Old 08-12-2009, 05:39 PM   #19
I like Green things
WarnerConstInc.'s Avatar
of oak siding!
I've seen chestnut, poplar, and white oak for siding and trim.
White oak was just trim though. Lots of western white pine too, mostley barn siding.
WarnerConstInc. is offline
Old 08-13-2009, 10:16 AM   #20
Store Owner
NCPaint1's Avatar
You guys ever seen IPE wood? Mostly used for decking...and man...its sweet. Expensive, but no more than that composite crap the box stores are peddeling. It will last longer too, and look nicer. Plus its fire resistant, the wood is so incredibly dense that it doesent like to burn. One of my fav's, off topic....but thought I'd share
NCPaint1 is offline
Behr paint...Why does it suck? JumboJack Painting & Finish Work 85 03-21-2010 10:44 PM
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 9 07-01-2009 06:26 PM
question about SW paint choices 72chevy4x4 Painting & Finish Work 5 06-21-2009 10:14 AM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
Best Paint for the Conditions? realpurty2 Painting & Finish Work 9 01-16-2008 08:02 PM
