Trade: int/ext painting
Exterior Flashing
im spraying the side of an exterior with satin. backrolled the first coat and just sprayed the second over top but i see its flashing. any suggestions? uneven coverage?
#2 | |
Pro Painter
Re: Exterior Flashing
Most likely it is uneven coverage. You probably should have back rolled both coats. This is the way we do it.
However, there are some other things to consider. Where and what is flashing? Are there primed or un-primed but scraped areas that are flashing? What type of substrate is it? What was it's previous condition. Did you change the sheen from the original paint? What type of paint are you using?
