Trade: .
Epoxy Coat On Top Of Epoxy Coat
Trade: Epoxy Flooring & Concrete Overlays
Re: Epoxy Coat On Top Of Epoxy Coat
sand with 80 grit floor sander wipe with xylene and goto town
This free one post wonder helpful tip brought to you by JBBS. Helping noobs and hacks, one post at a time. |
Side Effects May Vary
Trade: Professional Painting
I was gonna tell him to paint it with flat interior latex then epoxy over that, but I guess your way might work better. You are saint like with all the help you provide.
Whatever it takes for me to help another human being with the added benefit of being a contributing member of this fraternal order of professional contractors.
Handle It!
JBBS neglected to mention the Urine Coat.
The urine coat is only if you are installing Sexy Floors!
Handle It!
Re: Epoxy Coat On Top Of Epoxy CoatI missed that entire thread. Such a shame!!!!!
You have been missing alot lately. I am starting to loose my faith in you.
#9 | |
Handle It!
Re: Epoxy Coat On Top Of Epoxy CoatQuote:
Way beyond the level of acceptability and ease. Never mind my dedication to this place of escape.
dont bullsh!t us Malco, you found a m4m chat and now you no longer love us. Thats fine, I can take rejection, but think of Bodger, he is old, you were his last shot at romance.
Trade: .
Well, since you came back to give thanks I have to give you credit. If it is adhering well and just dull, sand it very well to make sure the entire area is scuffed and any loose areas are down to bare. If the entire floor is failing then yeah, you would want to diamond grind it all to a new surface, but I gathered from your thread it just needs refreshed. 80 or 60 grit paper, wipe with xylene/tack cloth. While I don't care for SW epoxy, I would use it in this situation just to make sure it is compatible and will bond.
vandy
Trade: painting, decorating, wallcovering
while applying epoxy floor finishes is not my expertise per se, i have use a lot of epoxies.
epoxy is a reactive (as opposed to evaporative) coating. even though the existing coating as totally cured, a fresh epoxy application, especially if the same product should eat into the existing coat. if the epoxy was waterborne, use waterborne again. the same goes for solvent based. what I would do: -give it a good sand with 60 or 80 grit as was suggested. (just scuff up the surface, dont sand off the existing especially since you say it is solid. -sweep and vaccuum as was also suggested. -give a good solvent wipe if the existing coating was solvent based, or a good alcohol based wipe if the existing was waterborne. (just make sure it is totaly clean OK) -apply the new stuff and make the homeowner swear on his own life that they will stay off of it for several days. fyi- the only reason the existing coating has held up so well is because the floor and garage are climate controlled. typically epoxy garage coatings are crap. good luck to you. fanatical homeowners are tough to work with at times but they yield a lot of work as they like to repaint and re decorate way more often than is necessary. |
#14 | |
Handle It!
It is not nice to hate the Player when you can hate the game........ You SICK Fooker!!!!!!!
| Scratch Coat | bline22 | Masonry | 23 | 03-01-2009 09:03 PM |
| Hamilton prep coat... | Halo | Drywall | 5 | 11-29-2008 12:51 PM |
| Epoxy Garage Floors | RoSSco | Painting & Finish Work | 8 | 09-04-2008 11:00 AM |
| Stucco Finish coat seperating from base coat? | mwcuff | Masonry | 9 | 08-16-2008 08:42 PM |
| Question about Epoxy clear top coat. | metomeya | Painting & Finish Work | 4 | 10-10-2006 09:26 PM |
