Trade: interior paint contractor and window treatment workroom
Encapsulating Lead Paint
ok...i'm back to get more information on lead paint...the state of pa. requires that you be cert. to REMOVE lead paint from a home...ok but what if there will be no sanding of the walls...just plan to encapsulate the lead...do you still need to be certified?? and if not what is the name of the product to encapsulate the lead?? or am i legally required to walk away from this job since i'm not lead abatement cert?? thanks lorna
#2 | |
...jammin
Trade: Rock Disciple
Re: Encapsulating Lead Paint
The state laws could differ, but I was always able to remove and replace (if it was trim) or encapsulate in the states I've worked in
I should mention, it's often worth it for the H/O to remove the lead If there is lead, or the possibility of lead, they must disclose that before sale/lease and that could effect sale/lease now or down the road
Signature Quote Quote:
Trade: rehabber
be very careful doing that work. your liability insurance probably has a an exclusion against doing lead paint remediation. if you want to get into that work, it can be lucrative, the problem is, workman's comp and liability are SKY high. as far as doing the work, check with your state department of the environment. in Maryland and dc, there is a 4/5 day course to get you licensed to do lead work.
as far as encapsulating it, in Maryland, all we need to do is make sure there is no chipping, peeling, flaking paint, and then you can encapsulate it with regular latex paint for a temporary fix. there used to be paints that were sold as encapsulating paints, and you needed to install them 7mm thick. because of the quantity of incorrect applications and the liability, these paints are becoming increasingly more difficult to find. once again your state department of the environment should be able to help you with finding them. if we want to do a serious encapsulation, we usually remove all existing trim, cover the walls with 1/2" rock, and then install new trim. |
Trade: paint
"Child Guard" which is a division of California paints. Great stuff. Goes above federal standards and is approved in all 50 states as lead encapsulate. Can be tinted or used as is(primer/encap) then painted over. But....around windows that slide it is still recommended to remove the lead.
child guard...that was it..remembered reading somewhere about that stuff...dog how do you apply it,spray or roll,need to sand first,do you need to wear heavy duty masks???..will call my my state office this week and find out what the requirements are,if i need to be cert. to encapsulate..
#6 | |
My custom title
CARC, Chemical Agent Resitant Coatings.. it what you are searching for. Gotta warn you though, each state is different but OSHA is not... it's expensive as ell, and too much for the average HO to afford to take care of properly.
BTW, look under industrial coatings for CARC paints... there are still several around.
Benn Quote:
thanks all your the greatest.... they indicated that this childguard is cert. in all 50 states here are some links i found
http://www.bobvilla.com/BVTV/homeaga...1224-03-2.html then search encapsulating and www.fiberlock.com/pds/childguard_pds.pdf Last edited by lornmastro; 10-01-2006 at 10:55 PM. |
#8 | |
My custom title
Ya, fiberlock rocks... just make sure to check out the OSHA things on encapsulation. Don't know about you but i've got the EPA and OSHA, plus local agencies, code enforcement PLUS workers comp inspectors all over this city, and they cruise every day.
Benn Quote:
will be calling them tomorrow and getting more info...will post what i find out....thanks again
F.y.i. i just spoke to someone from fiberlock ...he said that the childguard is really geared for the h/o..sold in paint stores...he indicted that LBC is the same product..applied the same way as childguard...but only sold to the industry in 5 gal....and the best thing...ta ta.... you don't have to be lead abatement cert. to use it....i'd double check with EPA just to make sure. thanks all for the information i needed your all the best!!
I was reading about this a while back and there is a product for this that is formulated to taste really bad just in case a rugrat decides to chew on a sill.
i know childguard has the stuff in it to make it taste bitter and since lbc is suppose to be the same stuff it must also have the bitter in it too
#13 | |
...jammin
Great detective work lornmastro
Thanks for the update
#14 | |
Professional Painter
Trade: Owner/Operator
Re: Encapsulating Lead PaintQuote:
I've used LBC and found it to be awesome stuff. Thick, good coverage, which makes it great for encapsulating. Just thought I'd let you know...No more lead jobs for me, I'll just use my tyveks and respirators for interior spray jobs...
Rich |
did a job a while ago where I removed lead paint (using a hammer drill with a grinder attachment
THANKS SLICK...thats what this forum is about..sharing info...couldn't have done it without you all....paint guy ,you don't have to use a respirators to use the LBC, do you???any special advice on the application??
#17 | ||
My custom title
Benn Quote:
#18 | |
All the lead jobs I've done were run by the state, so yes....they watch you like a hawk. Tyveks and repirators always. But even without that, it's lead dude! It's bad stuff. Wear a respirator. The side affects on you or future children could be real bad..... ![]() I always just brushed it. It goes on ok....
Rich |
| What Internet lead services should do to corner the market | Mike Finley | Business | 45 | 03-26-2010 09:17 PM |
| Lead base paint removal wood house. | welovepainting | Painting & Finish Work Picture Post | 10 | 08-25-2007 03:31 AM |
| Lead paint | Robie | Painting & Finish Work | 3 | 06-30-2006 08:54 PM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
