Eliminating Spray Gun Splattering
Well, today i must say that I had a bad day, and all because of my spray gun splattering. You see i started off the day by spraying some doors. I took them off, and set them up in the garage of the house(after setting up my spray booth of course). Anyways, as i started spraying, i noticed that when i would let go of the trigger of the spray gun, it would not stop co shooting paint completely, and instead would send paint splatters onto the doors. i Played around with the pressure thinking maybe that was it and nope it kept doing it. I was using a brand new fine finish tip as well. So now i have doors with paint splatters on them and to top it off, its oil based paint so i have to wait a whole day for the paint to dry before i can sand off the paint splatters.
do any of you guys have ideas as to why my sprayer does this?, i want to eliminate this problem, because if i am going to re spray the doors tommorrow i don't want those paint splatters. Any possible solutions? |
Re: Eliminating Spray Gun Splattering
Saucedo80:
My guess is either your gun has been sitting for a while, or it is worn out. What you have is not a problem with the tip, but a problem with the ball and seat of your gun. If it has been sitting for a while, there may be some crud on the seat. Other wise the gun is just worn out. They start spitting especially when spraying semi-gloss as they are dying. Rebuilding a gun only takes about 5 minutes, and should cost you less than $50. Hope this helps, Al |
thanks for the infor al it reallly helps. i think that the case with me is that there is crud on the gun since it isn't really that old. only about 3 years old. i am going to take it apart and clean it see if it helps. i have a spare gun that is much cleaner i will try that one tommorrow after sanding down the splatters on the doors. Kind of wanted to get the doors done on the first shot, but what the heck, sometimes you get these bad days, you just have to roll with the punches.
Trade: home remodel/deck builder
It's the packing in the gun thats causing the problem, just went through the same deal while spraying sanding sealer on cabinets, good thing it wasnt the finish coats of laquer. Rebuild the gun and the splater will go away, 3 years is a long time without changing the inards.
Trade: PAINTING
What Brand Of Gun Is It?
Custom Builder
Sauce, check the pin rod just above the trigger first. Sometimes if old paint or crud prevents the rod point from sliding forward and seating well the gun will spit.
Bob
Bob |
Its just like the one in your picture right under your name JAARONC
Trade: general contractor, plumbing and heating contracto
Unless you have used the hell out of the gun, just take it apart clean it and put it back together--it will work great. you must be sure the paint stop valve seats all the way forward into it's seat, however.
Trade: Painting and wallcover
buy habit I start and stop off the door just for this reason. Like to shot them flat if I can. After cleaning it you will need to adjest the fuild nut on the back of the gun.
MarkWoodCarpentry
If you cant fix it and need to getem sprayed just dont stop sprayin till your just past the door.
Mark Wood Carpentry and Welding Carpentry,Welding Pressure Washing,Painting Drywall Hanging and finishing |
#11 | |
Trade: mechanic
Re: Eliminating Spray Gun SplatteringQuote:
Trade: Drywall Finisher
Wow thats pretty much word for word of my day on Sat ....but mine was a rental , took it back for full refund and I've been hand bombing them since , working great and easier than i thought . Hope it turns out for ya
Just noticed date on OP ...
| Looking for a New Spray Rig | plazaman | Painting & Finish Work | 20 | 07-06-2007 09:53 PM |
| Painting Exterior EIFS Home / Spray Gun Setup | plazaman | Painting & Finish Work | 9 | 06-18-2007 11:03 PM |
| spray, brush, or roll doors? | Traditions | Painting & Finish Work | 13 | 03-31-2007 10:20 AM |
| regarding spray painting | gregferd | Painting & Finish Work | 1 | 03-05-2007 08:34 PM |
| Someone spray painted my trailer??? | dougchips | Painting & Finish Work | 5 | 03-05-2007 04:46 AM |
