Drywall Tape
Old 04-03-2006, 10:52 AM   #1
DonL's Avatar
Drywall Tape
Good morning. I am new to this forum and I have a question. I bid a painting job that the drywall tape is coming loose where the wall meets the ceiling. Some of it looks like it could be glued and remudded, but alot of it is bubbling up. Is it best to try and cut it out and retape it or is there a better way? Thanks
DonL is offline
Old 04-03-2006, 01:57 PM   #2
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Drywall Tape
best to cut it out and re mud the area,don't use hotmud (durabond 5,20 etc.I would use the green lid mud forgot who makes it ,it has alot more glue then all purpose gle,good luck
painterofeveryt is offline
Old 04-03-2006, 07:00 PM   #3
painterman's Avatar
Trade: Historic Restorations
Re: Drywall Tape
Tape may be coming loose for a reason. Could it be truss uplift? Is it worse in the winter? Try to determine what is causing the problem.
Stan
painterman is offline
Old 04-03-2006, 07:38 PM   #4
rob3429's Avatar
Trade: Painting and drywall
Re: Drywall Tape
Green lid mud is made by Sheetrock
rob3429 is offline
Old 04-03-2006, 07:41 PM   #5
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Drywall Tape
Stan
That was my first thought too, Stan....
Don, there may be more going on there that you can't see.. You'll be back next winter repairing it again if it is truss uplift!!!
maj is offline
Old 04-03-2006, 08:39 PM   #6
1Painter's Avatar
Trade: House Painter
Re: Drywall Tape
My drywall buddies told me years ago use fiberglass tape,mud, then paper tape over the top, and finish. Hope that helped ?
1Painter is offline
Old 04-03-2006, 09:26 PM   #7
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Drywall Tape
What would be the advantage to that????
maj is offline
Old 04-03-2006, 10:11 PM   #8
1Painter's Avatar
Re: Drywall Tape
So when it moves the fiberglass will give, and the paper will should not show crack, depends on how bad the wall moves.
1Painter is offline
Old 04-03-2006, 11:09 PM   #9
Redman's Avatar
Trade: Remodeling/Painting
Send a message via MSN to Redman
Re: Drywall Tape
mesh tape will be your best bet. wont bubble. a little harder to cover with mud but better in the long run for durability
One day at a Time.
Redman is offline
Old 04-04-2006, 01:09 AM   #10
trialbyfire's Avatar
Trade: shingler
Re: Drywall Tape
With me providing guarantees on my work, I would cut and re-do. But have a look first, for the obvious causes.
Kris
trialbyfire is offline
Old 04-04-2006, 02:36 AM   #11
1Painter's Avatar
Re: Drywall Tape
Cut out the problem area , Do you have all the knives and pan ??? This can be a learning process. I was alwalys told don't wait for a drywaller. We make them look GOOD !!!!!
1Painter is offline
Old 04-04-2006, 09:14 AM   #12
DonL's Avatar
Re: Drywall Tape
Thanks for the responses. I was concerned that it was truss movement. This could definatly be a learning experience.
DonL is offline
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 09:54 AM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
35,000 sq ft of commercial drywall to tape kaiberg Drywall 16 04-13-2008 05:49 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
