Drywall Repair Bleeding Through Paint - Why?
Old 12-02-2007, 01:23 PM   #1
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
I am finding that my minor drywall repairs (i.e. small quarter size holes, cracks, minor surface defacements) are bleeding through the paint. What I mean by "bleed through" is the outline of the dry spackle or drywall mud (after it is sanded down) or it's shadow is apparent after paint is applied and drys. You can only see the outline when it is in the light. My process would involve filling the hole, sanding, priming and painting with flat or eggshell (latex). I usually use 100% acrylic latex primer followed with good quality pain.
What am I doing wrong??? is this called flashing??? What would you suggest.
Thanks.
Zeebo
Zeebo is offline
Old 12-02-2007, 01:48 PM   #2
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Rewards Points: 250
Re: Drywall Repair Bleeding Through Paint - Why?
are you thinning down your mud at all ? it does shrink more when you thin it,hope this helps
painterofeveryt is offline
Old 12-02-2007, 01:57 PM   #3
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
Hi...thanks for the response. No I'm not thinning down the mud. The fill that I use is usally in the can, pre made, such as DAP. You just open the container, take it out with a knife and spread on the wall to fill the hole, crack, etc. After it drys, I sand and prime. When I apply the paint...and when the paint drys...I see the outline / shadow of the plaster repair in the paint....but only when light is put on it. Is this common or is there something I can do to prevent this??
Zeebo is offline
Old 12-02-2007, 02:13 PM   #4
It's all about the Avatar
woodmagman's Avatar
Rewards Points: 1,016
An existing wall has a texture to it from various coats of paint. If your patch has no texture then it will be seen as a patch. Piming and painting is the problem and the solution.
woodmagman is offline
Old 12-02-2007, 03:42 PM   #5
Workaholic's Avatar
Trade: Painting Contractor
I think light joint compund works better than spackle. Are you just trying to paint the spot? if so you might not be comming out far enough and you may be seeing where you sanded farther out on the wall.
If this not the case then you may want to prime, then put two coats of finish on your touch up area, especialy with eggshell or semi-gloss.
I would also suggest using a paddle mixer on a drill to mix your paint prior to touch up.
If all else fails you may have to repaint the whole wall, and that would be a real pain for a thumb sized spot.
Sean
Workaholic is offline
Old 12-02-2007, 06:10 PM   #6
Zeebo's Avatar
Trade: Painter
Rewards Points: 150
Thanks for the suggestion. I should have been more specific. I am actually painting the entire wall. My problem shows up when I am painting an entire room. I will fill holes and cracks, followed with sanding and spot priming and 2 coats of paint.
Thanks again,
Zeebo
Zeebo is offline
Old 12-02-2007, 06:25 PM   #7
painterofeverything
Rewards Points: 250
try durabond 5 or 20 and see if that helps the problem,still sounds like the thickest part of the mud is shrinking down a bit...
Old 12-02-2007, 06:38 PM   #8
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
Before you fill a hole, you might want to use the butt end of your knife, or screwdriver, and bang it into the hole to make a crater. This will soften the appearance of the edge of the hole, as well as ensure there are no high spots.
You might need two coats of mud. Or finer sandpaper. You should feel no edge whatsoever with your hand. And use a good primer. And while you are it, dont spot prime with a brush, use a mini roller to get some stipple on there.
Chris G is offline
Old 12-02-2007, 08:56 PM   #9
Rewards Points: 2,000
Originally Posted by Chris G View Post
.... And use a good primer. And while you are it, dont spot prime with a brush, use a mini roller to get some stipple on there.
Right on.
I like a 3/8 nap and a 3--4" roller. And either a PVA or Cover Stain on any raw spot repair.
neolitic is offline
Old 12-06-2007, 10:10 PM   #10
BMAN's Avatar
Trade: Painting & Remodeling
Rewards Points: 250
Most primers are a little thins o there will be a texture flash. Try primeing with the actual paint after the primer coat. use a roller to apply this finish coat prime.
BMAN is offline
Old 12-06-2007, 10:16 PM   #11
PlainPainter's Avatar
Rewards Points: 250
Ive noticed that mud repairs with 1 coat of primer and two coats of paint will have next to no stipple - while the rest of the wall which already has had like 4-8 coats of paint has stipple built up over time. So you see a difference where the paint is very flat over the patch and then immediately very stipply everywhere else. You just have to build up more paint over this area - I just accept it for what it is.
PlainPainter is offline
Old 12-07-2007, 12:05 AM   #12
Knowledgeable Tinter!
Faron79's Avatar
Trade: Painting/Hardware Retail
Rewards Points: 75
Maybe a stupid question...
Have you guys used the Spraytex from Homax?? For the "orange-peel" wall texture, it's a Godsend!!
The newer version of this has the little "droplet-control" tab on the spray-tip.
I'm no PRO by any means, but the Wife made me fix a corner-bead crack about 3ft. long on a higher wall (we were repainting anyway...). So, after sealing-off/filling/sanding this portion, I got the Spray-tex out and did a couple quick vertical-corkscrew-patterned passes.
Let it dry, and primed with my C2-One Primer , and 2 full coats of paint...and voila! I cannot tell there was a repair there!!!
For small areas, I just cut a hole in some cardboard slightly bigger than the repair, and make a 2 quick passes over the "hole"...one vertically, one horizontal.
Works for me anyway!
Faron
Faron79 is offline
Old 12-07-2007, 07:11 PM   #13
kdrose27's Avatar
Trade: Painting and Home repairs
Thumbs up
Are you using a water based filler? Try switching to a water based mud, what else may be happening is you are spreading the paint to thin on the wall. Dont be afraid to use the paint put a nice pro. coat not too much that it runs but enough to cover it evenly.
kdrose27 is offline
Old 12-07-2007, 07:29 PM   #14
Frankawitz's Avatar
Rewards Points: 1,196
Zeebo, what you have is new wall surface where you have repaired, to get the stipple that PlainPainter is talking about you can take a brush and dab the paint on over your repairs, hope there isn't a lot of them, or you could try this get a 5 of Block Filler and use a 1" or longer nap lambs wool roller skin, roll it over your repair this stuff sets up in about 15 to 20 minutes then you can paint your two coats of paint, as for primer it's a sealer it's not going to give you a lot of stipple, it soaks and being that it's thin like water, the Block Filler is like marshmellow fluff, so when it drys you have instance stipple.
Frankawitz is offline
Old 12-08-2007, 08:17 AM   #15
Any Season's Avatar
Rewards Points: 250
I agree, we usually fill and sand, then spot prime it when we are cutting the room in. Then before we roll the room, just run around and roll all the small patch spots, then just roll the walls as usual. No spots.
Any Season is offline
Old 12-08-2007, 12:52 PM   #16
BMAN's Avatar
Rewards Points: 250
Sometimes a whizz roller will also help build the texture back up to the new smooth patch.
BMAN is offline
Old 12-08-2007, 07:07 PM   #17
REGAL PAINTING
regal's Avatar
Trade: painting contractor
Rewards Points: 150
roll aura over that wall with a aura cover, no spot prime, and you will not see the repair/flash.
regal is offline
Looking for paint or drywall repair in Central Oh. jlower64 Help Wanted or Looking For Work 0 11-22-2007 03:46 PM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
Drywall repair - texture matching help build4Him Drywall 2 05-29-2006 08:50 AM
Dealing with flaking paint....help!!!! Zeebo Painting & Finish Work 9 11-28-2005 10:03 PM
