Dry Fall
Old 10-29-2005, 07:22 PM   #1
Wallcoat Joe's Avatar
Trade: Architectural coatings
Question
Dry Fall
I am bidding a large comm. ceiling with Dry Fall, can anyone tell me if I need primer with oil if the steel is primed except at the welds? Should I prime the galv. sheet metal ceiling? My foreman says he has done a few for the last company he worked for and only applied 1 coat wih no primer in beither oil or water borne, but the MPI hints otherwise. Any help? THX
Wallcoat Joe is offline
Old 10-30-2005, 07:58 AM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Dry Fall
Wait a minute, isn't dryfall what happened to that chic in the Brian Adams music video 'cuts like a knife'.
Bob
Bob
Glasshousebltr is offline
Old 10-30-2005, 09:23 AM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Dry Fall
Sorry, I have never sprayed dryfall myself. In your case, I would be torn between doing what the instructions said, and using my foremans experience.
Hopefully, someone else will pop in with advice.
Bob, turn off MTV, and get to work.
ProWallGuy is offline
Old 10-30-2005, 11:22 AM   #4
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
Re: Dry Fall
We have sprayed a comm. steel ceiling before. 18' up and the dryfall from SW worked great. We did prime it, we used the primer that the guys at SW recommended, 401 I think. We did the ceiling black so we got it tinted gray and did two coats of the dryfall black.
http://www.humbleabodepainting.com/curveswb.html
The pictures don't really do the ceiling justice, because of those huge lights.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 10-30-2005, 11:32 AM   #5
K2's Avatar
Re: Dry Fall
I worked on a large building back in 98 where the guys spayed the ceiling and then spent the next 3 weeks powerwashing it off. I didn't catch all the details but they said something about a light coat of oil on the galvanized. The fellows had it ready for opening day but I can't imagine they made any money on that one.
K2 is offline
Old 10-30-2005, 12:12 PM   #6
Painting Contractor
Re: Dry Fall
Yeah Galvanized needs to be washed before it can be painted... There is a thread here somewhere about it.
The NAPP
Old 10-30-2005, 05:02 PM   #7
Dripless
Dale's Avatar
Trade: Painting and exterior wood care
Re: Dry Fall
Heres a link for info on galvanized steel.
http://www.galvanizeit.org/content/i...=291&navID=335
Dale is offline
Old 10-30-2005, 09:23 PM   #8
Dripless
Dale's Avatar
Re: Dry Fall
If you can find the March/April 05 issue of PWC magagine there is a good article on galvanized steel..what to looks for..a couple of simple tests to see if the galvanized is ready for painting etc.
Nothing looks worse that paint failing in mass on galvanized metal. Fixing it must be a pain in the azz. I'd say be careful.
Dale is offline
Old 11-01-2005, 09:54 AM   #9
Re: Dry Fall
hanks for the help, I found that with oils you must prime. Water bornes on the other hand goes either way, If you use a higher end product no primer is needed but two coats are suggested. You would be amazed at the inconsistencies of information out there. Again, thanks.
Old 11-02-2005, 10:14 PM   #10
saucedo80's Avatar
Re: Dry Fall
what is dryfall?
saucedo80 is offline
Old 11-02-2005, 11:41 PM   #11
Painting Contractor
Re: Dry Fall
Originally Posted by saucedo80
what is dryfall?
Paint that dries as it falls. Leaving only a fine dust when it hits the ground. SW sells it.
The NAPP
OSHA says I should have had fall protection americangutters Health & Safety 86 04-14-2011 03:26 AM
Fall Protection Question CC1 Health & Safety 19 07-14-2008 04:44 PM
Fall protection costs? Safety Dog Health & Safety 2 02-03-2007 05:20 PM
One Week Until Fall denick Excavation & Site Work 6 09-18-2006 06:05 AM
