Dried Roller Cover Removal?
Old 04-09-2007, 09:35 PM   #1
Property Manager
steve-in-kville's Avatar
Trade: Drywall/Textures/Paint
Thumbs down
I was using some oil primer on a project about a month ago. I almost never use oil. At the end of the day, I wrapped the roller in a plastic bag. This kept the roller wet for the following day. Sometimes it went a week before I needed the oil primer again. The plastic bag always kept the roller wet.
Anyways, *someone* forgot about the oil roller that was left in the basement, still wrapped in a plastic bag. I found it almost a month after we wrapped up the project. Dried hard as a rock. No use salvaging the cover, but the frame was one of the better ones that SW sells. I'd normally just chuck the whole thing, but would like to salvage the frame.
I have it soaking in thinner now. What are the chances I can remove the cover? I'm hoping that the cover will soften so I can at least cut it off.
Lesson learned. Make sure that *someone* accounts for his tools after a job!!
Thanks for the help.
steve
Originally Posted by Paintguy26 View Post
.... everything was all warm and cushy until this.... please comfort me and say that someone held a gun to your head and made you say that
steve-in-kville is offline
Old 04-09-2007, 10:09 PM   #2
George Z's Avatar
Trade: Painting Contractor
Re: Dried Roller Cover Removal?
steve
Hammer it off the cover.
George Z is offline
Old 04-09-2007, 11:02 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Chalk it up to experience and buy a new roller. Its likely you'll kill the roller trying to remove the nap anyways. Or, like George says, just use the BFH.
ProWallGuy is offline
Old 04-09-2007, 11:07 PM   #4
mdshunk's Avatar
Not having ever done this, I wonder that with the amount of thinner, disposal labor, labor to remove cover, etc, if you wouldn't be further ahead to throw it out? I suspect that the "rolling parts" of the frame will never be quite the same now that paint has dried in them. Hard to say. Just talking out of my ear a little bit.
mdshunk is offline
Old 04-10-2007, 01:33 AM   #5
Woz the Painter's Avatar
steve
I would take it to the nearest nuclear power plant and ask if they could put it in the reactor for a week or two....
Woz the Painter is offline
Old 04-10-2007, 01:45 AM   #6
Joewho's Avatar
Trade: Painter
Had the same thing happen on occasion. Never found an easy way to take the dried cover off. heres a couple of ways though.
Hammer the end cap. Usually won't work though and may break the end cap. hammer inside the arm of the roller frame. Again, chances are it won't work, but it might.
I usually wind up sticking the sharp end of the 5n1 under the roller and cutting/tearing the ends and then peeling it off. Another way is to razor knife a spot open in the center, then tear it off, or cut it off.
Now that it has spirits on it, there will be a mess. To me it's not about saving the roller, it's about the challenge.
Joewho is offline
Old 04-10-2007, 07:57 AM   #7
paintr56's Avatar
Trade: paint contractor since 1974
Steve,
You should use stripper to lossen dried paint. That should soften it enough to get your roller. Or as mentioned cut it off.
Jim Bunton
paintr56 is offline
Old 04-10-2007, 08:45 AM   #8
MakDeco's Avatar
toss it and buy new, your time and energy your wasting on figuring this all out is costing you more money than replacing it!
I usually keep some cheap rollers on hand for oil primer use them once and toss them!
MAK Deco
MakDeco is offline
Old 04-10-2007, 09:16 AM   #9
bill r's Avatar
Trade: residential (marine) piers
life is too short
bill r is offline
Old 04-10-2007, 09:22 AM   #10
Frankawitz's Avatar
Get some Laqucer thinner or try brush cleaner let it soak for a day or so it will come right off.
Frankawitz is offline
Old 04-10-2007, 07:29 PM   #11
My custom title
Brushslingers's Avatar
It's dead Jim.
But ... we may.... be able... to salvage...
JIM, get ahold of yourself!
Benn
Originally Posted by Brian
Brushslingers is offline
Old 04-10-2007, 08:31 PM   #12
Workaholic's Avatar
Ditto
Sean
Workaholic is offline
Old 04-10-2007, 10:17 PM   #13
House Painters Reading PA
4thGeneration's Avatar
Do yourself a favor and realize like I did that it is easier and more productive to buy new naps instead of trying to use a wore out one over and over. Besides, I would not pay a painters wage or a helpers wage to clean one out when you can buy a good one for 3 or 4 dollars.
4thGeneration is offline
Old 04-11-2007, 12:53 AM   #14
paintr56's Avatar
I know this post is about saving a roller frame but i have to say I did what you said for many years. This winter I bought some $15 lambswoool covers and loved them then I bought the Rejuv-a-Roller takes about 30 seconds to put the cover in the tube then turn on the water and walk away to do something else come back in 3 or 4 minutes to a clean cover remove from tube spin or just let dry. I have used one roller 14 time so far it is still working great holds paint well doesn't shed. I even started washing my cheaper covers takes so little time and effort it is easier then buying new.
Jim Bunton
paintr56 is offline
Old 04-11-2007, 11:51 AM   #15
Workaholic's Avatar
Jim Bunton
Are you talking about oil? because i have cheap covers i use for oil so that they are throw aways. Water based i have good lambs wool that gets washed.
Sean
Old 04-11-2007, 01:01 PM   #16
paintr56's Avatar
I am talking about water based. I throw away oil covers also.
Jim Bunton
paintr56 is offline
Old 04-11-2007, 09:46 PM   #17
Property Manager
Originally Posted by Brushslingers View Post
It's dead Jim.
Thanks for the many comments of this. I decided to feed the dumpster and disposed of the old cage and cover . Lesson learned.... the hard way.
steve
Old 04-12-2007, 08:26 AM   #18
straight line's Avatar
Trade: carpentry,general contracting
Next time you might try cutting a slot out of the cover lengthwise.
straight line is offline
One more airless power roller question steve-in-kville Painting & Finish Work 5 09-19-2008 11:09 PM
Titan power roller... My first impressions steve-in-kville Painting & Finish Work 0 06-17-2007 11:22 AM
ok I found the name for roller cover washers !! painterofeveryt Painting & Finish Work 19 01-07-2007 04:35 PM
2 Power Roller Options... which is better? kenrie Painting & Finish Work 8 10-12-2006 04:19 AM
pricing wallpaper removal lornmastro Painting & Finish Work 23 09-21-2006 09:40 PM
