Door Stain
Old 12-05-2017, 10:24 AM   #1
rpmhillc's Avatar
Trade: Home Improvement
Door Stain
Bought this wood door at a builder auction for dirt cheap. No markings on brand or species of wood. Going to stain both sides and use for a front entry door. My front porch sits 12' back from the roofline, so the door never gets wet. Was planning to use Minwax but wasn't sure about finish. Thought about using Minwax Polyshades but didn't know for sure if it needs to be sealed. Can I use regualr Minwax stain, or do I need to use a topcoat which would be a satin?
rpmhillc is offline
The Following User Says Thank You to rpmhillc For This Useful Post:
AmericanPaint (12-05-2017)
Old 12-05-2017, 12:40 PM   #2
Renaissance Man
superseal's Avatar
Rewards Points: 4,856
Re: Door Stain
Looks like clear pine to me and polyshades has the stain and finish top coat in one. Not the best choice, but not too bad of a product if you ask me.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Old 12-05-2017, 01:05 PM   #3
rpmhillc's Avatar
Re: Door Stain
MY biggest concern with the polyshades is the fact the the 1st coat is the only coat that absorbs. You just don't get the rich color from multiple coats. After further digging, I might end up using an exterior toner from Olympic Elite.
rpmhillc is offline
Old 12-05-2017, 01:38 PM   #4
rrk's Avatar
Rewards Points: 646
Re: Door Stain
Try varathane stains also available from home depot. I used them a few times and had good results on pine
rrk is online now
Old 12-05-2017, 01:57 PM   #5
tjbnwi's Avatar
Rewards Points: 1,036
Re: Door Stain
Zar.
tjbnwi is offline
Old 12-09-2017, 05:11 PM   #6
Gumshoe's Avatar
Trade: Painter
Rewards Points: 34
Re: Door Stain
I'm a big fan of Old Masters stains and polys.
Gumshoe is offline
Old 12-13-2017, 06:10 PM   #7
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 297
Re: Door Stain
You could practice on the top or bottom with whatever product you decide on. My last choice would be Minwax though. Since it won't see the weather, I would use a Spar Varnish to topcoat.
Do you have a local paint store that maybe carries a line of professional coatings, like Mohawk, General, MLC, etc. ?
Does not look like pine--maybe doug fir?
rescraft is offline
