Dogs Are Killing My Freshly Painted Doors, Customer Not Thrilled
Old 01-13-2018, 10:08 AM   #1
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 1,194
I知 a bit out of my depth on this, I admit.
So I did some work for a pet resort/pet daycare type place that included repainting some metal doors. No one could be certain what product was on the doors already, but it appeared to myself and my painter to be something like a latex DTM. Admittedly, I知 not a paint expert but I tended to agree with him, and he is a good painter that I致e used many times and generally trust. They were scratched up and had some light rust. We sanded the rust spots, lightly sanded the rest of the door, and primed the rust spots. Then painted with latex DTM. I believe the primer was a red oxide type.
Anyway, the dogs apparently just abuse the hell out of this door. I知 talking big dogs jumping repeatedly on it dragging their claws down. There is a window in the top half of the door, and they are doing the worst damage on that metal trim, but also getting the face of the door.
I sanded it lightly and repainted yesterday afternoon and asked that they keep he dogs out of there until Monday to give it time to fully cure out. However I知 a little worried that it will happen again.
Same job also had 2 metal posts in a play area which get peed on often and the bottoms were rusting badly. We scraped, sanded, and cleaned them up, but impossible to get all the rust off without grinding it down and probably making it weak. Again used the red primer, then the latex DTM. I知 having a some rust spots pop through after only a few days. We did have a time constraint so the primer did not fully cure, and we did primer and top coat same day. Dogs were back in the room next day.
Does anyone have any tips or a better product that I could use on those sides of the door that take that abuse and on the posts? It痴 also notable that this room is a very humid environment due to the constant washing down of everything.
Thanks
Sent from my iPhone using Tapatalk Pro
Bearded Wonder is online now
Old 01-13-2018, 10:18 AM   #2
Mordekyle's Avatar
Rewards Points: 2,652
Re: Dogs Are Killing My Freshly Painted Doors, Customer Not Thrilled
Not trying to be snarky, just curious.
Does direct to metal DTM paint need to be applied directly to Metal? Will lit bond to previously painted surfaces?
I painted my galvanized Topper ladder rack with it. It's not as tough as I had hoped.
Mordekyle is online now
Old 01-13-2018, 10:22 AM   #3
Trade: General
That question has occurred to me as well. I do not know, although I assumed that you could re-coat with good results.
Old 01-13-2018, 10:35 AM   #4
tjbnwi's Avatar
Rewards Points: 1,036
Should have used this primer on the doors;
https://www.paintdocs.com/docs/webPD...269000d1a738da
This on the posts;
https://www.por15.com/POR-15-Super-S...lack_p_11.html
tjbnwi is online now
Bearded Wonder (01-13-2018)
Old 01-13-2018, 10:45 AM   #5
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,616
I'm not sure you can win this one. Get the doors powder coated? Maybe they need stainless or brass covers on the doors. A lot of paint won't really cure for weeks.
Golden view is online now
The Following 3 Users Say Thank You to Golden view For This Useful Post:
AustinDB (01-14-2018), Bainbridge (01-15-2018), Gumshoe (01-14-2018)
Old 01-13-2018, 10:52 AM   #6
VinylHanger's Avatar
Rewards Points: 6,924
Dog claws and whizz will destroy anything. Maybe rivet a plexiglass panel on the door after you paint it.
Maybe wrap the posts with Azek?
I hope you're not repainting for free. Not your fault the dogs are clawing the doors.
And yep, you need a rust stop coating on the posts first.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
Rio (01-13-2018)
Old 01-13-2018, 11:00 AM   #7
Lazy Millennial
Youngin''s Avatar
Rewards Points: 54
It's almost like you need truck bed spray liner. Dogs are hard on pretty much every surface.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is online now
The Following 2 Users Say Thank You to Youngin' For This Useful Post:
Rio (01-13-2018), sparehair (01-13-2018)
Old 01-13-2018, 11:18 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,056
Por15 is crazy hard.
I'd skin it in stainless.
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
Robie (01-13-2018)
Old 01-13-2018, 11:32 AM   #9
avenge's Avatar
Rewards Points: 2,568
Humidity is not good paint won't cure properly. I probably wouldn't have painted any of it.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Old 01-13-2018, 12:19 PM   #10
Texas Wax's Avatar
Rewards Points: 694
Oversized Stainless kick panel, like the ones in hospitals. Width of door up about 32"-36"
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 01-13-2018, 12:19 PM   #11
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,629
Sounds like you need a sacrificial door in front of it. Kind of like those double-gated entries at some dog parks.
MarkJames is offline
Rio (01-13-2018)
Old 01-13-2018, 05:38 PM   #12
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,080
I like the stainless skin idea on the door and would also go with POR on the post. Get the small starter kit with the cleaner and prep solution included.
BBuild is offline
Old 01-13-2018, 05:43 PM   #13
Trade: General
Do you have to order that stuff or can you pick it up at local retailers?
Old 01-13-2018, 07:51 PM   #14
tjbnwi's Avatar
Go to the link I posted. Click on store locator. Advance Auto Parts and the SW Automotive Finish store near me stock it.
You can order it through the link also.
Old 01-13-2018, 10:36 PM   #15
Designer/Contractor
Rio's Avatar
Rewards Points: 422
The dogs will win every time against paint............
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
hdavis (01-14-2018)
Old 01-14-2018, 05:22 AM   #16
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,252
"Dogs are killing my..."
I see that, and I immediately think its Davis posting about his girlfriends chickens getting et up again.
I've used 5 maybe 6 vets over the last 35-40 years. Never saw the "Dog Damaged Door" phenomenon.
Net Zero Energy Is Here Now
典he worst day working for yourself, is still better than the best day working for someone else!
..Jim Rohn
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (01-14-2018)
Old 01-14-2018, 08:44 AM   #17
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 2,066
I used POR 15 inside my rusty motorcycle tank. Works great but I think overkill for that. I think an epoxy paint might be the best cost/effort way to go but it still won't solve the main problem, the dogs shouldn't be able to get to the door if they want the door to look decent. Why don't they have a chain link gated fence? It would be a better way to let dogs in and out too.
RangoWA is offline
Old 01-14-2018, 10:01 AM   #18
AustinDB's Avatar
Rewards Points: 470
If the client is leasing the premises, they may be less likely to invest in a better fix The POR15 fix should be a solid fix if given the time to dry. Maybe the client is willing to buy a second door and you can properly prepare/paint it, then after it's cured, install the door.
My first thought for the post was to wrap it and use a polyurethane sealant at the bottom to keep it from wicking into the concrete.
AustinDB is offline
Old 01-14-2018, 10:45 AM   #19
hdavis's Avatar
Rewards Points: 3,447
If you can't wrap, there are epoxy marine coatings that will work, but I think you'll have to blast to use them.
hdavis is offline
Old 01-14-2018, 12:04 PM   #20
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,363
Corothane HS
https://protective.sherwin-williams....3Aproduct-6810
It痴 expensive!
WBailey1041 is offline
Therma-tru French doors SUCK! Help!! 01chevduramax Windows, Siding and Doors 5 12-30-2013 07:37 PM
Best method to paint new wood pre-hung doors BElliottP Painting & Finish Work 7 12-17-2013 06:36 AM
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 12:23 PM
24" exterior doors - where to buy? Panzer5 Carpentry 11 05-07-2009 08:43 AM
