Does Any One Make A Low Pressure
Old 04-01-2007, 10:28 AM   #1
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Does any one make a low pressure sprayer?
I like the pressure when my sprayer is turned down but it makes the stupid lines. We do a lot of work in urban areas and can't spray because of cars driving by.
HUDSONVALLEYEXT is offline
Old 04-01-2007, 10:42 AM   #2
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Re: Does Any One Make A Low Pressure
You mean versus an airless? Check out an HVLP setup.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 04-01-2007, 01:56 PM   #3
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
if you are having problems with overspray ,an hvlp IS NOT GOING TO BE LESS OVERSPRAY ! one idea, use a bigger tip spray and backbrush ,if applicable...
painterofeveryt is offline
Old 04-01-2007, 05:15 PM   #4
farrellpainting's Avatar
Trade: exterior painting contractor
Iv'e never used one myself, but have you ever tried a roller attachment for your spray rig?
farrellpainting is offline
Old 04-01-2007, 08:31 PM   #5
painterofeverything
I have used them before,and can honestly say,that for the right surfaces power rollers are the bomb !
Old 04-01-2007, 08:54 PM   #6
My custom title
Brushslingers's Avatar
Ya I have a low pressure sprayer, but it's older than you prolly.. heh, check campbell hausfields website... the one I have is 1500 psi but, in wind... overspray is still an issue.... I use it for oil.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 04-02-2007, 06:41 PM   #7
Educated Applicator
MarvinWilleyJr's Avatar
Trade: Painting & Fine Finishes
Send a message via AIM to MarvinWilleyJr
What?
What do you think the HVLP is for? It will have less overspray are you kidding?
Backbrush...... haven't heard that terrible saying in a long time!
MarvinWilleyJr is offline
Old 04-02-2007, 08:00 PM   #8
painterofeverything
Originally Posted by MarvinWilleyJr View Post
What?
so you dont think that nice fine mist is going to blow for miles ?and why is backbrush a terrible term ? with oil stain would you leave it on the surface or brush it in ?
Old 04-02-2007, 08:12 PM   #9
Educated Applicator
The HVLP has a very low waste factor, that's the point of the low pressure. Thus making very little overspray.
As for backbrushing behind a sprayer.........that's what you have to do when you can't spray. After you learn to spray.......then you don't need to "backbrush" the runs you had, because you know how to spray.
Old 04-02-2007, 09:12 PM   #10
PlainPainter's Avatar
Doesn't anyone like to backbrush after spraying - 'cause it works the paint, stain or whatever better into the surface? I use the sprayer as a way to apply paint to the surface and reduce all that time you do dipping your brush into a bucket, loading, and then applying - and the brushing out. Spraying is great for applying - but doesn't substitute for brushing the paint out. These are wood surfaces people - not perfectly smooth primered sheetmetal!
-plainpainter
PlainPainter is offline
Old 04-02-2007, 09:50 PM   #11
Workaholic's Avatar
Trade: Painting Contractor
-plainpainter
Nope i spray a primer on the wood, and then sand, then spray finish. The only time i would use a brush on my sprayed work is if there was a run or sag. Which does not happen in this weather. I like the sprayed look with out brush strokes. I also do not spray stain i use the older method for that.
Sean
Workaholic is offline
Old 04-03-2007, 02:20 PM   #12
painterofeverything
[QUOTE=PlainPainter;220768]Doesn't anyone like to backbrush after spraying - 'cause it works the paint, stain or whatever better into the surface? I use the sprayer as a way to apply paint to the surface and reduce all that time you do dipping your brush into a bucket, loading, and then applying - and the brushing out. Spraying is great for applying - but doesn't substitute for brushing the paint out. These are wood surfaces people - not perfectly smooth primered sheetmetal!...Nice to see that someone understood what I meant ! for rough sawn exteriors,backbrushing is the only way to go !!!
Old 04-03-2007, 02:24 PM   #13
painterofeverything
Gee,marvin,I guess you would never spray and back brush an exterior log home.or some solid color stain on the exterior rough sawn lumber in florida...how nice that you choose to not work the paint into the woods surface and let it sit on the surface..quality work down there eh ?(bet you would'nt use an oil product outside either right ?
Old 04-03-2007, 03:14 PM   #14
boman47k's Avatar
And I thought the purpose of backbrushing/rolling was to make touchup easier. However, I have done very little spraying, none on walls or trim. So I really know next to nothing about it, only what I read and try to decipher.
Well, I did spray my abestos exterior here. I just used a Wagner that I have. I did not backroll though since this is my place anwayway, and I was kind of playing. One day I will finish the backside.
boman47k is offline
Old 04-03-2007, 03:36 PM   #15
Workaholic's Avatar
Back brushing a rough surface makes sense. I do not usually spray exterior, unless i can do it before the roof goes on.
So i was speaking from an interior aspect.
Sean
Old 04-03-2007, 06:44 PM   #16
Educated Applicator
Sorry guy but around here the guys I hear using the backbrushing term are the drunks.....I heard one say he was gonna spray the trim and he needed a back brusher. I said wtf?.....he wanted me to follow behind his expert spraying and catch the runs on the casings and doors.
Relax champ.
Old 04-03-2007, 07:00 PM   #17
painterofeverything
was and am totally relaxed,type better that way !! over ...
Old 06-03-2008, 02:15 AM   #18
SPRAYMAN FOAM MECHANIC
hawkpbt44's Avatar
Trade: sprayman urethane foam and coatings
GRACO CAN HELP YOU WITH THAT PROBLEM!
hawkpbt44 is offline
What features/specs to look for in a pressure washer? steve-in-kville Painting & Finish Work 11 06-03-2008 02:17 AM
your pressure tester POOLMANinCT Pool Construction & Enclosures 2 06-11-2007 11:46 PM
Increasing pump pressure Teetorbilt Plumbing 2 02-24-2007 10:40 PM
pressure washing HUDSONVALLEYEXT Painting & Finish Work 69 12-14-2006 11:21 PM
water pressure with on demand heaters Vermonster Plumbing 2 11-11-2006 07:14 AM
