Do Not Buy The Wagner Painteater
Old 05-26-2009, 06:07 PM   #1
RoSSco
Guest
RoSSco's Avatar
Posts: n/a
Wagner painteater is a spinning mechanism with paint removal discs for $16. The painteater itself goes from $60 -80. Now I am sure not many of you are in the market for a painteater but I just wanted to make sure. You can buy an angle grinder for as cheap as $35. They make paint removal discs for angle grinders that are exactly the same as the 3m ones that wagner uses, but cost only about $6.00 (conviniently for Wagner they are not threaded the same and wont fit on a painteater) Even the cheapest angle grinders spin faster and remove paint quicker than the painteater. Not to mention angle grinders serve many other purposes besides removing paint.
Having said that, this method of paint removal does have its pros and cons compared to traditional methods. If you are trying to strip paint that is not loose or pealing you will have to use the edge and risk digging into the wood. However these are excellent for feathering. If you have just a few spots that need to be scraped and feathered, you can do it in minutes and the edge will be feathered perfectly.
Old 05-26-2009, 07:49 PM   #2
4thGeneration
Guest
4thGeneration's Avatar
Posts: n/a
Re: Do Not Buy The Wagner Painteater
I leave wagner up to the home owners. They also own Spray Tech and only used one my Uncle bought years ago. It had problems also.
Old 05-29-2009, 01:08 PM   #3
premierpainter
Guest
premierpainter's Avatar
Posts: n/a
Thanks for the advice. Paint shaver pro makes a great sander out of an angle grinder. Try that one....you'll never go back to those pads. Also, how do you collect the dust w/o a vac hook-up?
Tags
feather, paint removal, painteater, strip
Wagner Titan XT 330 for Commercial Use ckobesko Painting & Finish Work 7 06-09-2011 10:11 PM
Wagner Power Rollers? Yes or No Richard Painting & Finish Work 23 06-03-2009 05:39 PM
wagner compact hvlp regal Painting & Finish Work 2 10-21-2007 09:42 PM
Wagner Painteater bigbrew Painting & Finish Work 7 02-13-2007 08:18 PM
Wagner Paint Crew? RobertF Painting & Finish Work 10 04-18-2006 05:34 AM
