Determining If There Is Lead In Paint - How To??
Old 02-17-2008, 10:33 AM   #1
Zeebo's Avatar
Trade: Painter
I am now living in an area where many of the homes are 50-100 years of age. Customers are requiring repaints of baseboards, walls, ceilings, etc.
Most of these homes have been repainted with latex or oil 10-20 years ago. So if there is lead, it has been covered up with paint. However, I am still somewhat anxious about potential health problems. It is my understanding (whether this is correct or not) that I am ok if I don't sand it.
  1. Should I be concerned about lead in paint??
  2. More specifically, is there a "do it yourself" test that I can do (without the need to call in the lead experts) to determine if there is lead in paint??
  3. How do I protect myself....simple respirator with filter??
Thanks
Zeebo
Zeebo is offline
Old 02-17-2008, 10:38 AM   #2
Re: Determining If There Is Lead In Paint - How To??
Lead was banned in 1978.
Before that...
be surprised if it doesn't
have lead in it.
Lead tastes sweet,
if you want to try the
"Pepsi Challenge" method.
neolitic is offline
Old 02-17-2008, 10:38 AM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
You can use one of these to check for exposed lead.
ProWallGuy is offline
Old 02-17-2008, 10:38 AM   #4
Forry's Avatar
Trade: General Contractor, Remodeler
Yes, yes, and yes.
Be concerned about lead in paint for more than one reason... Your health, your clients health, your everything. You can go to prison. Don't remember the source, but prison is definitaley sp? an option.
A lead test kit is available at most hardware stores.
A dust mask is ok, but there's better systems.
Forry is offline
Old 02-17-2008, 10:43 AM   #5
Remember, the test kit is testing
the surface not what's under
the latest coat of latex.
When it comes to wood work,
stripping is better than sanding,
as far as containment goes.
neolitic is offline
Old 02-17-2008, 11:23 AM   #6
ibsocal's Avatar
Trade: Pain
yes it was banned from production in 78 but whatever stock was left over it was used up after 78.if u have to prep below the safe top coat try make as little / no dust you can use tyvec suit head to toe respirater with hepa filters and cover nearby areas with visqueen,if u have to make a lot of dust use a vent system with hepa filters and enclose work area.post signs secure area.but who really does all this = expensive for home owners.
ibsocal is offline
Old 02-17-2008, 11:57 AM   #7
Frankawitz's Avatar
Well heres the thing, The EPA Law states "That if your going to remove any surface bigger then a 2'x2' area and the house was built before 1989 you have to tell home owner that there could be lead base paint under the surface paint" as long as you don't sand it I would not worry about it, the problem comes when you sand it and turn it to airborn dust that you can breathe in. If you don't sand it your good to go.
Frankawitz is offline
Old 02-17-2008, 08:01 PM   #8
Zeebo's Avatar
Trade: Painter
Guys Thanks For All Feedback And Suggestions...i Knew I Could A Lot Of Info From Your Expertise. I Definitely Learned Something.
Zeebo
Zeebo is offline
Old 02-17-2008, 10:09 PM   #9
plazaman's Avatar
epa should have a list of approved coatings to encapsulate the paint.
plazaman is offline
Old 02-18-2008, 09:41 AM   #10
Zeebo's Avatar
Trade: Painter
Ok good info. But what about sanding the top coat??? Let's say that the lead paint has had a number of top coats, either latex or oil, over the the years. Is it safe to just do a light sanding of the top coat (the latex / oil) to establish a grab surface for a new coat of latex?? If I sand the top surface (which results in minor dust) will I be inadvertantly releasing lead from the original surface??? I don't think so, but your comments are very welcomed.
Thanks again.
Zeebo
Zeebo is offline
Old 02-18-2008, 09:57 AM   #11
One could lightly sand some trial
patches and test.
Or TSP then Cover Stain.
And I'd like to hear what experience
the pro's have had with chemical
"sanding" agents? This might be
a good place to use one, if they're any good.
neolitic is offline
Old 02-18-2008, 10:28 AM   #12
Zeebo's Avatar
Trade: Painter
patches and test.
Thanks for the suggestions Neo
Zeebo is offline
What Internet lead services should do to corner the market Mike Finley Business 45 03-26-2010 09:17 PM
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
Determining if latex or oil base paint gary lee Painting & Finish Work 6 07-31-2007 01:02 AM
encapsulating lead paint lornmastro Painting & Finish Work 17 10-03-2006 09:50 PM
Lead paint Robie Painting & Finish Work 3 06-30-2006 08:54 PM
