Trade: painting contractor
Determining If Latex Or Oil Base Paint
Does anybody have a surefire way of knowing if there is oil base paint or latex on a substrate? Usually I can tell by the way the paint has layed down if it is oil or latex. Another way I have used to determine if it is oil or latex is by rubbing it with denatured alcohol (latex will remove), but do not have total confidence in this test. Thanks for the feedback.
Gary |
Home Improvement Guy
Trade: Renovations contractor
Re: Determining If Latex Or Oil Base Paint
I trust goof off more than denatured alcohol. I don't know why, maybe I'm a goof
Don't worry, the baseboard will hide it! |
Trade: Painting & Remodeling
Latex and Oil taste different to me.
turning houses into homes
Trade: Wallcovering Installation
I always used the alcohol test, but then I met up with some latexes that did not "dissolve" with alcohol.
This, I copied from an Internet source (hey, if it's written, it must be fact "To test you can use methyl hydrate (gas line anti-freeze) or non acetone based nail polish remover. Apply a small quantity to a pad and rub vigorously on the painted surface. If the surface remains shiny it is oil/alkyd; if the paint is stripped it is latex." |
#5 | |
...jammin
Trade: Rock Disciple
I do the Goof Off! if I'm unsure
There is an alcohol test I like also Get drunk enough and you don't care what the substrate is
Signature Quote Quote:
#6 | |
Back from the dead...
Trade: Paperhanger/Painter
Re: Determining If Latex Or Oil Base PaintQuote:
#7 | |
Paint Pro/Faux Artisan
Trade: Painting Contractor/Faux Finisher
Bay Area Painting Company |
| why is latex paint peeling?? | Zeebo | Painting & Finish Work | 24 | 05-28-2009 07:59 AM |
| latex semi gloss over oil semi gloss - can it be done? | Zeebo | Painting & Finish Work | 13 | 09-05-2007 06:38 PM |
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| SW Latex Paint taking long to dry | plazaman | Painting & Finish Work | 9 | 08-10-2007 08:20 PM |
| best way to tell if the wall has oil or latex paint?? | Zeebo | Painting & Finish Work | 7 | 11-10-2005 07:03 PM |
