Deck Staining Methods?
Old 02-21-2007, 10:42 AM   #1
JMG1959's Avatar
Trade: General Contractor ( Central Texas)
Which is your application or method of choice? Brushing, Rolling, Spraying?
I have to refinish and stain a Deck and I want to complete it in the shortest amount of time possible. Any advice from you Pros out there would be greatly appreciated.
JMG1959 is offline
Old 02-21-2007, 11:49 AM   #2
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Re: Deck Staining Methods?
1) Apply a good cleaner (not bleach based). If there is failing stain on the deck, you have to remove it with a stripper.
2) Wash with pressure washer nozled down to 800 psi or so. On a 4 gpm machine a number 10 orifice is a good choice. Make sure you use steady even passes. If you stop or jerk along a floorboard, you will get lapping lines.
3) pH balance and brighten with a mild acid.
4) Let dry to 15-15% moisture content.
5) Apply high quality, oil/alkyd based semi transparent sealer with an airless or HVLP and backbrush into wood. Mask the floor under the rails and thn start by sealing the rails first.
We use a product which is an oil based that can go on wet wood (contractor available only right now, so you have to order it in). We can do a 500 s/f deck with rails and steps in one day using this product. If you want.. pm me and I will give you the company contact info.
Also take a peak at my website www.restore-a-deck.com. Its consumer based but there is a ton of info on technique and information on sealers in my newsletters.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 02-21-2007, 11:54 AM   #3
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
a garden pump sprayer works well for decks and fencing.
cheap too.
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 02-21-2007, 12:49 PM   #4
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
If you are doing a deck that is not your own. I would call in a pro for you don't destroy their deck...
HUDSONVALLEYEXT is offline
Old 02-21-2007, 01:53 PM   #5
Charitable animal
Bone Saw's Avatar
Trade: decks
I like to pre stain with a roller before I start building anything, but if its already built i'd go with rolling
Bone Saw is offline
Old 02-21-2007, 02:22 PM   #6
Mike Danahy
Danahy's Avatar
Trade: Signature Painter
Without going into too much detail, I can't tell you how fun staining a deck is when you can attach a large stain brush to an extension pole.
I like to brush stain into the grooves/grains by hand, but also like the option to do it standing as well.
Should someone else from standing roll the stain to the deck, then you brush also while standing behind them... well that's a good time.
This is all fine and dandy, after the appropriate prep of course.
Danahy is offline
Old 02-21-2007, 02:38 PM   #7
...jammin
slickshift's Avatar
Trade: Rock Disciple
I call it "The Dance"
I'll often have audiences for that part
And I do accept tips
That's it though, no roll, no spray, just a bigazz Bestt Lieco and six feet of Wooster Sherlock Positive Lock Extension Handle
Signature Quote
slickshift is offline
Old 02-21-2007, 03:02 PM   #8
Deck Cleaner
One other note: Your best bet on floors (even if you spray) is to use a pad.
Ken Fenner
Pressure Washing PA
Old 02-21-2007, 03:28 PM   #9
roofwiz74's Avatar
Trade: roofing
edit,sry
Old 02-21-2007, 05:09 PM   #10
Joewho's Avatar
Trade: Painter
rough rider works too. Just use a pan instead of a bucket.
Joewho is offline
Old 02-21-2007, 05:12 PM   #11
My custom title
Brushslingers's Avatar
I tip and roll stain, though I spray soild body.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 02-22-2007, 12:07 PM   #12
TexSeal's Avatar
Trade: Exterior Staining and Painting
What type of stain is currently on the deck? Solid or semitransparent?
Oil or Latex? What type of stain are you planning to use? How big is the deck?
Brush up against home 1 foot away.
Spray with pumpup sprayer between boards.
Roll on thick.
Go over with clean roller.
No time at all!
TexSeal is offline
Solid body deck staining Mike Finley Painting & Finish Work 5 05-30-2007 10:52 PM
deck staining bigdawg Painting & Finish Work 9 03-06-2007 01:25 AM
methods for staining woodwork Traditions Painting & Finish Work 10 03-01-2007 09:10 AM
Opinions on product for staining deck dwbrooks Painting & Finish Work 4 06-21-2006 07:13 PM
Deck Restoration & staining AHS Painting & Finish Work 2 05-10-2006 09:19 PM
