Deck Staining
Old 06-10-2006, 04:49 PM   #1
joedonuts's Avatar
Trade: carpenter
Deck Staining
I need some advice on staining decks and fencing. The wood is all pressure treated. The fence pickets are 3.5 inshes wide, spaced 1.25 apart. The stain is water based. The stain manufacturer says i can use a garden type pump sprayer to apply the stain. I have no luck with this method of application, the stain does not come out of the sprayer with a nice fan spray, it's more like a stream. So i am applying it with a 9" paint roller and brushes. Anybody have a better way of doing this. Thanks.
joedonuts is offline
Old 06-10-2006, 05:55 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Deck Staining
I tend to use pad pads on those
Truthfully I use mostly oil, but I'd use them if I had a water-based stain
You can get a groove going with them that's really very quick
Word of warning: Do Not Use The Cheap Ones...no W*M or HD, go to the Paint Store or Hardware Store for them...or if the local Big Box has Shur-Line they should be OK
When using the pads for stain they can be very drippy, the cheap ones couldn't hold stain if you glued it in there
I'll use the larger pads for the deck, and smaller ones for the balusters (pickets)
It sounds like you've got those panel type pickets, it'll probably be the same sized pad as you'd use for the decking
You sometimes still need to brush here and there, but not much if you do
I may have brushed a very small deck or two here or there over the last few years, but mostly I use the pads
Signature Quote
slickshift is offline
Old 06-10-2006, 06:37 PM   #3
rws's Avatar
Trade: paint contractor
Send a message via AIM to rws
Re: Deck Staining
S W sells some nice pump sprayers for this with a wide spray pattern
rws is offline
Old 06-10-2006, 10:04 PM   #4
Sprays Water
FCPWLLC's Avatar
Trade: Pressure Washing
Re: Deck Staining
Airless Sprayer and back brushing.
First Choice Power Washing LLC
Lexington, KY 859-983-5955, Member of Better Business Bureau, Greater Lexington Apartment Association ,Insured and Licensed
Pressure Washing Cleaning Service Lexington KY
FCPWLLC is offline
Old 06-10-2006, 10:15 PM   #5
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
Thank you everybody for your help! I am going to try a painters mitt to get in between the pickets. I bought a pump sprayer at S W and it does not give me a nice fan spray so i resorted to rolling with a nine inch roller and brushing in between the pickets. I'll give the mitt a try tommorow. The airless sprayer sounds like it might be the way to go, but i am worried about overspray blowing around and getting on windows and cars, etc.
Old 06-19-2006, 07:03 PM   #6
bigchaz's Avatar
Trade: Wood Restoration/Refinishing
Re: Deck Staining
Dont know if you did the job already, but those painters mits suck pretty bad. You should be able to get a smaller pad inbetween the pickets easier than a mitt.
bigchaz is offline
Old 06-19-2006, 08:39 PM   #7
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
Chaz i already started and the mitt is working great. the pickets are spaced about 1 1/4 to 1 1/2" apart, it gets in between pretty good, i am making good time with it, it seems to be laying a good coat on them. the face of the pickets is 3 1/2".
Old 06-19-2006, 10:24 PM   #8
bigchaz's Avatar
Re: Deck Staining
Ok well if its working for you thats cool! What product are you using on it? How much you charging per foot?
bigchaz is offline
Old 06-20-2006, 06:58 PM   #9
Dorman Painting's Avatar
Trade: Painting Contractor
Re: Deck Staining
Sherwin Williams sells pump sprayers made by Olympic that work very well. I've even used these sprayers to apply stain to log cabins. I've had wonderful success using these sprayers coupled with the DeckScapes waterbourne products. The think to remember about decks and staining them is that you're only going to get a couple of good years out of the stain. For fences, the only way to stain them is with a sprayer, either an airless or one of the Olympic that SW sells.
Dorman Painting is offline
Old 06-24-2006, 10:46 PM   #10
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
This job is for a property management co. that oversees condos and townhomes properties , did not price it per square foot, i priced it per building.
Old 06-24-2006, 10:47 PM   #11
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
SW Deckscapes water based
Old 06-24-2006, 10:49 PM   #12
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
I bought the pump sprayer, spent about 30.00 for it, it does not give a good fan spray. maybe the one i bought is not the one you are describing, but i am making good time though here as long as it doesn't rain.
Old 06-25-2006, 12:44 AM   #13
General Contractor
jensenconstruction's Avatar
Trade: General Contracting and Painting
Re: Deck Staining
we use the juice box http://www.juiceboxllc.com/info.htm or an airless. In my experience those pump sprayers just don't produce a consistant spray pattern.
jensenconstruction is offline
Old 06-30-2006, 11:51 PM   #14
joedonuts's Avatar
Trade: carpenter
Re: Deck Staining
Thanks for the link, that looks a good way to go!
Solid body deck staining Mike Finley Painting & Finish Work 5 05-30-2007 10:52 PM
deck staining bigdawg Painting & Finish Work 9 03-06-2007 01:25 AM
Deck Staining Methods? JMG1959 Painting & Finish Work 11 02-22-2007 12:07 PM
Opinions on product for staining deck dwbrooks Painting & Finish Work 4 06-21-2006 07:13 PM
Deck Restoration & staining AHS Painting & Finish Work 2 05-10-2006 09:19 PM
