Deck Sealing
Old 10-28-2007, 02:41 AM   #1
youngblood88's Avatar
Trade: Flooring
Deck Sealing
I was wondering what the normal price is to seal a 20 by 20 deck with 2 coats. I was also wondering if anyone knows do u have to power wash it before or will a simple hose off or sweep off be good enough. The deck is fairly new about 1-2 years
youngblood88 is offline
Old 10-30-2007, 01:04 AM   #2
carolinaprowash's Avatar
Trade: Exterior Surface Specialists
Re: Deck Sealing
You need to find out how to prep a job properly before you go pricing a stain job......if you seal/stain over dirt & mold/mildew, your stain will fail before you get to the bank.
If the deck has never been sealed or stained you can prep it with a light, non aggresive cleaner (LOW PRESSURE 500 psi -if you use a pressure washer) - a deck wash solution. Let it dry sufficiently (per the mfg suggestions) before applying the stain.
20 x 20 deck. Elevated or ground level, rails, spindles, steps? You probably need to measure more accurately or you'll find yourself short on product as well !
Carolina ProWash
Graham, NC 27253
336-270-4598 Office
336-516-6139 Roger 336-516-6356 Celeste
carolinaprowash is offline
Old 10-30-2007, 06:23 AM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Deck Sealing
There's no "normal price"
Call three companies for estimates, you'll get three different quotes
Signature Quote
slickshift is offline
Old 10-30-2007, 10:23 AM   #4
HUDSONVALLEYEXT's Avatar
Trade: EXTERIORS
Re: Deck Sealing
you should only coat once. I would charge about $500 if you don't powerwash it will turned black in a month
HUDSONVALLEYEXT is offline
Old 10-30-2007, 11:03 AM   #5
Barry M's Avatar
Trade: pressure washing/low pressure roof cleaning
Re: Deck Sealing
Deck sealing is just the last step in the wood restoration process. You can't skip the other steps and just jump to the last one and expect the deck to look good. The number one reason a sealer fails is because the wood was not prepped properly. If you just sweep the deck off and rinse it down it won't matter if the sealer you put on it is $100 a gallon, in three months the sealer will have failed and the deck will look like crap.
As far as one coat or two coats it really depends on the sealer being used, follow the manufacturers instructions. Without more information about the deck it is really hard to just throw a price out there. There are too many variables involved and you haven't given us enough detail.
Barry Maddox - Midwest Pro Wash
Pressure Washing Indiana
Deck Cleaning
Barry M is offline
Old 10-30-2007, 02:47 PM   #6
aceflooring's Avatar
Trade: Flooring, Concrete Stamping, Staining, Overlays, & Remodelings
Re: Deck Sealing
if its a two coat seal its cheep crap remember its your reputation. and a 2 coat sealer well 2 coats costs twice as much.
aceflooring is offline
Correect Deck ?'s Robert and others IHI Decks & Fencing 9 05-21-2008 10:45 PM
Ipe Deck rjordan392 Decks & Fencing 19 10-10-2007 10:58 PM
Dry lower deck stuff frostyfrost Decks & Fencing 12 05-19-2007 07:59 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
