Dealing With High Raised Edges Due To Combing Effect
Old 04-19-2009, 07:11 AM   #1
davidanbess's Avatar
Trade: Painting and Decorating
Hi, what would be the most effective way to red rid of these lines/raised edges,the h/o wants to get rid of the comb effect she had on her bedrom walls.I have not seen the job yet but will be going later on today. Is it a case of sanding away high edges and then priming then mudding and priming again or could you just sand then mud. I know sometimes from previous posts I tend to answer my own question but I think it's down to the fact that since moving here from the UK I seem to doubt my own ability over procedures and therefore need confirmation and reassurance from this site. thanks btw
Regards David
davidanbess is offline
Old 04-19-2009, 08:08 AM   #2
Dan-Liquid Art Design
LAD's Avatar
Trade: Decorative Finisher
Re: Dealing With High Raised Edges Due To Combing Effect
I go over old 'faux' all the time. Usually the mil of the glaze/paint used is not enough to warrant mudding. A simple sand and a couple fresh coats I find levels things off. If the finish was done with more of a texture material that's a different story. You may have to do a test area to justify your bid and altered price. Cover yourself!
www.LiquidArtDesign.com
LAD is offline
iridescent effect on soffit/fascia scott72901 Specialty Coatings 4 04-04-2009 10:47 AM
High of 72 CrpntrFrk General Discussion 24 02-27-2009 12:35 AM
High Profile Job: Local TV Set basswood Finish Carpentry 5 02-14-2009 04:36 PM
Have the shingle prices had an effect on your business? J-Peffer Roofing 19 10-11-2008 02:35 PM
Dealing with Floor Joists dcapone Low Voltage 0 08-18-2008 02:45 AM
