Dead Pressure Washer
Old 09-20-2007, 09:33 AM   #1
birdog's Avatar
Trade: Painting Contractor
My washer has been running good then has a hard time starting up on other days, finally the other day I could'nt get it to start, it has fresh gas so I change the spark plug, I only use it about 6 times a year so I took it in to a large contractor equipment/rental business. They called me and said that the pump was shot with corrosion. repair quote $410, the unit is a honda engine 6.5hp with a Annovi Reverberi pump and the cost new was about $700-800. I guess my question is would a bad pump not allow the engine to turn over,should I pay to repair or try to do it myself. This was a Home Depot pressure washer .
birdog is offline
Old 09-20-2007, 11:08 AM   #2
Dustball's Avatar
Re: Dead Pressure Washer
I had a pressure washer that wouldn't start- had spark and fuel but just wouldn't start. Turns out it was a broken cam.
Dustball is offline
Old 09-20-2007, 02:54 PM   #3
kapena's Avatar
Trade: General Building Contractor
The clowns at the repair shop are probably just going to replace the old pump with a new one that they bought on ebay for less than $200. including shipping. You can easily do the same thing yourself instead of paying $400.+, if you are not in too much of a hurry. Don't forget to put some gear oil in the housing before bolting it on if you decide to go that route.
It's possible that a bad (jammed) pump would keep the motor from starting, since it is a direct drive. It could be something else altogether,as Dustball said.
kapena is offline
Old 09-20-2007, 08:04 PM   #4
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Do you run chemicals (like bleach) through your pump?
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 09-20-2007, 09:32 PM   #5
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
Does it have enough oil in the crankcase? I have a Graco with a Honda engine that has a "low oil shutoff".
Stacy
S B Bolson & Sons
jackrabbit5 is offline
Old 09-20-2007, 09:42 PM   #6
plazaman's Avatar
The pump should affect if the engine starts or not i would tend to think.
I pump went out 2 months ago and the engine still worked. Dont pay 410 to repair it. I have a 5hp honda and paid about 150 for a replacement pump.
Im pretty sure you can find a replacement for a bit over 200. Takes about 10 mins to replace. Simple
plazaman is online now
Old 09-20-2007, 11:30 PM   #7
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
It may have been the pump, but I agree with everyone else- do it yourself and save bucks.
The other thing - since you only use it occasionally, do you put a gas treatment in the tank? Over time, gas will absorb moisture, especially in high humidity areas. Treatments absorb the moisture, too much water will prevent it from firing... just because you put fresh gas in it doesn't necessarily mean there wasn't moisture in tank.
LAstly, you put a new spark plug in it - did you check if there was spark?
Bob
Bay Area Painting company
Da Vinci is offline
Old 09-20-2007, 11:56 PM   #8
Deck Cleaner
The problem with the "home cheapo" machines are that the unloader is built into the pump and those are usually proprietary and can be expensive to replace.
Ken Fenner
Pressure Washing PA
Old 09-21-2007, 01:07 AM   #9
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
I had one Anno-Reverbi pump. It died and I went back to the General Pump, they give much better service. If it going to cost $700 to fix your home cheapo, would it be cheaper to rent a PW 6 times a year and let someone else have the repair bills? or just toss the home crapo and buy another cheap PW?
fireguy is offline
Old 09-24-2007, 02:28 AM   #10
toddcla2002's Avatar
Trade: Paint Contractor
Send a message via AIM to toddcla2002
I had a similar experience. I used to have a Home Depot pressure washer with a Honda 6.5. I don't remember the pump....it eventually died. I got a quote for about the same amount as you to get it fixed and they said that it would probably have the same problem after awhile because it's essentially a homeowner model and the parts aren't made to last forever. (it's cheap). I have since spent money and bought a nice industrial one. So I would consider getting an industrial one. Maybe one that was lightly used as a rental or a heavily discounted one from a paint supplier or something. Good luck!
~todd
toddcla2002 is offline
Old 10-02-2010, 04:11 PM   #11
ED_Painting's Avatar
I got one of those and died if you are talking about the dewalt. It lasted 5 years washing 50-70 houses a year. Couldn't ask for more bought another one same exact one.
At sw they are selling those mi t m but there's not much feedback on those.
Painting Contractors
ED_Painting is offline
Old 10-03-2010, 06:59 AM   #12
Andrew M.'s Avatar
Too many items to list unless you narrow it down, I do all my own repairs on basically everything.
For pumps, CAT is the one to buy. Had 2 AR's wear out, went to CAT's and zero issues.
Ok, as an ex mechanic, you have to go thru the spark, electrical,fuel checks. The low oil ignition shutoff circuit is an easy check. There are even you tube video's. You can disconnect the pump fr. the engine to isolate but I doubt , unless frozen would stop the start. If the AR is an axial cam pump, well then yes it could be trashed and I would get rid of that and get a CAT as a replacement if you like the PW otherwise. General makes good triplex cam pumps too a slight step below CAT overall. Do not buy axial cam pumps unless you want trouble. I assume you mean a commercial GX Honda engine not the consumer line.
My DW's are the older models with CAT pumps and GX engines. I like them very much. MiTM's are usually overpriced.
Andrew M. is offline
Old 10-03-2010, 07:54 AM   #13
Anti-wingnut's Avatar
Thanks Andrew,
I'm sure the OP has been waiting for three years to hear from you before they make a decision of what to do
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Steve Richards (10-03-2010)
Old 10-03-2010, 08:17 AM   #14
Steve Richards's Avatar
Trade: hack painting
Originally Posted by Anti-wingnut View Post
Thanks Andrew,
Why does it seem like new people always bring old threads BTT?
Do they join just so they can?
I'm not complaining, Ed.
(because I'm not a complainer)
You have every right to post in any thread you want.
Last edited by Steve Richards; 10-03-2010 at 08:20 AM. Reason: edited to sound less like a complainer
Steve Richards is offline
Old 10-03-2010, 10:01 AM   #15
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Steve, I think what happens is they do a search on something they are wanting to get information about,
or while they reading a recent thread down towards the bottom of the page there is this:
Sir Mixalot is online now
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Old 10-03-2010, 10:08 AM   #16
Yup.
You'd think I'd have figured that out (me being a brainiac and all)
Old 10-03-2010, 12:41 PM   #17
Andrew M.'s Avatar
Thanks Andrew,
You are very not welcome.
There was a reply just before mine, not years ago, Oh, I guess you did not see that. I did not look the date of the OP.,was on the front page list as current topic, so I answered just was trying to help out . What an inconvenience for you as to be forced to type a sarcastic reply, and did you ever think that it might help someone else, searching on this subject in the future anyway? I guess not. What a disaster, I wasted a few digital bytes. I will be more careful in the future as not to waste anyone's time esp. my own.
Old 10-03-2010, 12:43 PM   #18
yeah wingnut..ya grumpy old bastard!
The Following User Says Thank You to Steve Richards For This Useful Post:
Anti-wingnut (10-04-2010)
Old 10-03-2010, 12:51 PM   #19
Tom Struble's Avatar
Trade: siding
get it right Steve he's anti-wingnut grumpy ol bast*d
Tom Struble is online now
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Anti-wingnut (10-04-2010), Steve Richards (10-03-2010)
Old 10-04-2010, 09:40 AM   #20
Help, somebody call the wambulance! Poor Andy, some mean person made a little jokey wokey about you, and now the tears roll out.
Get a grip. This is an inter net forum for adult construction workers, who are typically male. If my little on-line joke offended you so much, maybe you should quit the trades and get a job at Jo-anns Fabrics. There the mean old ladies will treat you with the kid gloves you so despertley need
Replacement pump for pressure washer T bone Pressure Washing 5 08-01-2008 12:56 PM
What features/specs to look for in a pressure washer? steve-in-kville Painting & Finish Work 11 06-03-2008 02:17 AM
TSP & pressure washer Teetorbilt Painting & Finish Work 25 04-28-2008 05:28 PM
What size pressure washer and tip do I clean a deck with? jimb317 Painting & Finish Work 11 07-02-2007 01:43 AM
pressure washer Traditions Painting & Finish Work 10 05-06-2007 11:54 AM
