Cypress Siding 2 Coats TWP (natural) Application Technique 4,000 Sq Ft. Advice - Page 2 - Painting & Finish Work - Contractor Talk
Old 04-13-2017, 11:23 AM   #21
402 Painting's Avatar
Trade: PAINTING CONTRACTOR
Rewards Points: 68
Re: Cypress Siding 2 Coats TWP (natural) Application Technique 4,000 Sq Ft. Advice
Originally Posted by Railman View Post
I used to use a fruit sprayer combined with a fruit sprayer + compressor + presure regulator. Then brush out with a small broom head like hdavis referenced.
Today I would just use a paint pot with about a 5ft ext wand added fruit sprayer nozzle. The light pressure spray gets it on everything at all angles, & the broom brush gives max penetration, & even application.
Wow i have never done anything like that but that sounds like an amazing system and assuming much less overspray
402 Painting is offline
Old 04-13-2017, 11:46 AM   #22
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,200
Horizontal with a six inch wide x 36 inch long mini roller. Purdy collosus nap.
Maybe have a couple naps on hand that first day to see which one works best.
Sent from my SM-N910T using Tapatalk
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
402 Painting (04-13-2017)
Old 04-13-2017, 06:37 PM   #23
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 836
Is it possible to just spray this job successfully without all the backrolling/brushing methods described? Yes it is. Wham bang, thank you ma'am.
Caslon is offline
The Following User Says Thank You to Caslon For This Useful Post:
Old 04-13-2017, 10:43 PM   #24
Rewards Points: 68
Went out there today to play around finally had a nice weather day. Thankyall so much for the advice and opinions. I can see why TWP recommends a conditioner to open the pores. It just does not want to soak in. It looks like little pinheads of stain because it won't absorb correctly. Builder wanted to try without though and see if home owners approve it. So we will see tom. I did not have to cover all the stucco like i thought even though it is windy as hell because it is on a lake. i just used a 412 tip and sprayed and back brushed. i just plastic out like 8 ft. The biggest brush sherwin williams had was a 4" purdy. It worked but i need a bigger brush for 4098 sq ft surface area. I sprayed 2 boards side by side and back brushed one for comparison. They looked the same until they dried and the one that was not back brushed looked like crap. I also tested back rolling with a 3/8" nap synthetic nap and that left too much on. Main problem though it won't soak in as aforementioned so the roller leaves way too much. This is pretty easy overall Sometimes i have a lot of anxiety about results and its never as bad as i think ! wasted worrying ! smh
The Following User Says Thank You to 402 Painting For This Useful Post:
sparehair (04-14-2017)
Old 04-13-2017, 10:43 PM   #25
Rewards Points: 68
damn my pics did not post let me try again !
Old 04-13-2017, 10:46 PM   #26
Rewards Points: 68
well none of my pics will load SMH
Old 04-13-2017, 10:55 PM   #27
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,136
careful with TWP we did a few decks with it last year and had problems with it looking shinny in places. Which as it turns out was because we did not wipe all the excess stain off right away.
Anderson is offline
The Following 2 Users Say Thank You to Anderson For This Useful Post:
AustinDB (04-14-2017), parkers5150 (06-25-2017)
Old 04-14-2017, 08:09 AM   #28
AustinDB's Avatar
Rewards Points: 790
100 or 1500? Does 1500 behave like 100 (only stuff I've used)?
AustinDB is offline
Old 06-25-2017, 03:20 PM   #29
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
sooooo???? howd it turn out?????
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Need Blasting Equipment AND advice.... fishwich2005 Sandblasting 4 09-02-2014 08:54 PM
Base for natural stone steps advice oxygenrace Masonry 1 11-03-2013 06:57 PM
Lotta wood, #1 common white oak, finished natural pinwheel Flooring Picture Post 18 05-31-2013 10:01 PM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 08:58 PM
need siding contractor advice in a bad way... A&E Exteriors Windows, Siding and Doors 91 03-18-2011 12:05 AM
