Cutting In Question
I am getting fairly good at cutting in (what an art!) but once in a while I will get a stream of paint too close to an edge. I've tried scraping the brush on the can to see if I can get the paint absorbed with a stroke, but that doesn't work. I'm talkin' about the paint that is so close to the edge that if you try and flow it out, it'll hit the wall/molding/ceiling.
How do you folks handle this?
I'm just stirring the:
Trade: .
Re: Cutting In Question
I am not positive I fully understand the question, but keeping one of those el cheapo foam rubber rubber brushes handy does this for me. These will absorb that little bead of paint just fine.
In fact, for cutting in the front of the house (I just finished all but the 2nd top coat of trim and the doors) I used a foam brush for cutting in exclusively. It worked better than I thought it would so I didnt bother with the bristle brushes I got. It was tedious at times but the sharp edge of a new foam brush allowed me to get some very sharp straight lines in areas where there was to be a color change (wood around window frames). Another little hint that I taught myself was instead of using the small factory pre-cut paint rollers, I cut my own from larger rollers using a steady hand on the sawzall. I made a really fine edge which unlike the pre-cuts was NOT tapered on the end. I then pulled out any loose fuzz from the cut area. This small square edged roller allowed me to roll the area of the cut in VERY closely (~1/8 inch) which I could not have done with a factory made roller which is tapered on the ends. Hope this helps. I am sure real painters have a far more elegant solution to give ya. I'll learn from them too!
Memorable Places - My little home on the web Member of the White Knights Of Contractor Talk |
I 'dump the brush', put the majority of the paint on the wall in a few long strokes and then work it to the edge. If the bead gets to the run point, pull away and start over. When cutting, clean your brush about once an hour, paint on the bristles will start to dry by then and you begin to lose your flow. The goobs will also start causing drips.
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
| Cutting steel roofing-what do ya'll use | IHI | Roofing | 9 | 07-02-2006 07:41 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
