Cutting In Curved Drywall Edges
Old 02-19-2006, 11:51 AM   #1
aoc's Avatar
From time to time I have to change the color from one room to another
that has the curved drywall edges. Taping pulls the mud off the primed
and previously painted edge especially if there is a light texture on it.
What would the best way to paint the edges?
thanks
aoc is offline
Old 02-19-2006, 12:13 PM   #2
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Cutting In Curved Drywall Edges
try using a heat gun to warm the sticky residue before removing the tape ,and pull slowly ! and at a 45 degree.
painterofeveryt is offline
Old 02-19-2006, 02:03 PM   #3
aoc's Avatar
3m 60 day tape was used.
thanks
aoc is offline
Old 02-19-2006, 02:27 PM   #4
Professional Remodeler
firemike's Avatar
I use low-tack tape, I can't remember who makes it (Most paint stores have something similar, I get mine at Sherwin-Williams) it has just a bit more tack than a post-it note, and is a little thinner than regular tape. It is mainly used for stripes, but works well for changing colors. When I apply it, I press it on and use a clean rag to press edge tight and rarely have any problem with bleeding, and that is usually only if the existing surface is really rough.
firemike is offline
Old 02-20-2006, 07:55 AM   #5
painterofeverything
and previously painted edge especially if there is a light texture on it. thats why I suggested using heat ,so it will loosen the adhesive qualities.3m 60 day tape is only meant for 60 day clean removal in direct sunlight if I am not mistaken.
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 09:54 AM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
Best Tool For Cutting Edges bigbrew Roofing 20 02-07-2007 10:01 AM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
