Crappy Wood Filler
Old 05-01-2007, 10:03 PM   #1
Carpenter/fencing
nywoodwizard's Avatar
Crappy Wood Filler
I Built a mantle a few months ago and used some i think elmers wood fill it actually expanded out of the screw holes,i only used a few screws,thank god,its all biscuts and finish nails. i can kick myself in the ass for using this crap,i'll have to dig it out and use something else.just to think i'm the one always telling people not to get cheap,i don't meet my own standards,i hang my head in shame
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 05-01-2007, 10:16 PM   #2
Scott Young's Avatar
Trade: carpenter/remodeler
Re: Crappy Wood Filler
for what you are going to use it for i use dap plastic wood. it is acetone based and cures very fast.
Scott Young is offline
Old 05-02-2007, 07:04 AM   #3
Professional Painter
Richard's Avatar
Trade: Owner/Operator
mh readypatch
Rich
Richard is offline
Old 05-02-2007, 11:03 PM   #4
Paul B's Avatar
I plug screw holes.
Paul B is offline
Old 05-03-2007, 12:41 AM   #5
ibsocal's Avatar
Trade: Pain
automotive type spot putty two component dries quick sands smooth.
ibsocal is offline
Old 05-03-2007, 09:49 PM   #6
Carpenter/fencing
Originally Posted by Paul B View Post
I plug screw holes.
I considered that but it was only a few holes and it was being painted,i think it had something to do with the heat of the fireplace.
Old 05-04-2007, 06:20 PM   #7
Workaholic's Avatar
Trade: Painting Contractor
I use crawfords putty. Was this mdf that you used?
Sean
Workaholic is offline
Old 05-04-2007, 06:24 PM   #8
Workaholic's Avatar
Automotive bondo is not a great thing to use if you are using it in new construction. Had a trim guy swear by how great it is, he applied it, sanded it. And we primed it and painted it. Then when we go to do final, it was all cracked out. Causing us a lot of extra work. IMO the only place for it in residential construction is for metal doors.
Sean
Old 05-04-2007, 11:44 PM   #9
ibsocal's Avatar
Trade: Pain
you might could have experinced seperation with the bondage stuff if not allowed propper cure time prior to sanding,i have not yet and have gone through over 20 gal of the stuff on manny types of substrates .again i use automotive "spot putty" two component type with excellent results for small fill jobs like the kind you had issues with.
ibsocal is offline
Old 05-04-2007, 11:54 PM   #10
Teetorbilt's Avatar
Wood expands and contracts depending upon humidity and temperature. Polyester products (Bondo) are ridgid and shrink over their lifetime (undetermined).
Albert Einstein
Teetorbilt is offline
Old 05-05-2007, 12:29 AM   #11
ibsocal's Avatar
Trade: Pain
good point.just about every thing on this earth expands and contracts including you, even steel.polyester has plastic in it so it bonds and expands and contracts with any given substrate.3" steel plate on a aircraft carrier flight deck expands 1"-3" in length during flight opps coated with epoxy non skid coatings which are more rigid than polyesters and i have never seen a coating failure due to expansion contraction.have you ever seen a part of a fender fall off where it had bondo,me never.even tiajuana bondo holds up.so i thinks it could have been improperly applied over dust dirt oils debris which could have caused a adhesion/coating failure
ibsocal is offline
Old 05-05-2007, 09:50 PM   #12
Carpenter/fencing
It was MDF , But using mdf isn't uncommon for fireplace mantles,and a relativly stable wood once acclamated,it only happened on the screw holes though,not the finish nail holes ,the mystery deepens .So i may have to blame it on a number of things,the heat caused wood expansion and forced the filler out,pretty consistently too, there all up about a 1/6,the screw itself absorbs heat also, and may have also contributed,or just crappy filler.Live and learn i suppose.
pls help.. wood filler problem cynthiann Painting & Finish Work 5 03-19-2009 01:45 PM
which wood filler? rocco Carpentry 10 03-18-2009 12:40 PM
Wood Filler navco1390 Painting & Finish Work 3 01-26-2007 10:31 AM
wood filler recommendation on crown molding JRicker Finish Carpentry 14 01-24-2007 08:59 PM
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 03:09 PM
