Old 08-14-2007, 07:37 PM   #1
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Coverage? Linear footage
I need a number to get me close to what a gallon of good paint brushed over primer on say a 4 inch baseboard will cover in linear feet. 600 ln ft? 800?
Mike Finley is online now   Reply With Quote
Old 08-14-2007, 08:16 PM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Mike, unfortunately all the production rates I do are based one 1 sq ft. Even a 1" thick pipe at 1' long would be designated 1 sq ft. I figure paint to cover 350 sq ft. So it would probably be safe to say a gallon would cover around possible maybe 425-450 ln ft.
ProWallGuy is offline   Reply With Quote
Old 08-14-2007, 08:20 PM   #3
MODERATOR
ProWallGuy's Avatar
More info, my 2004 Paintcost Book says a gallon will cover approx. 675-750 ln ft of 1"-3" base. So knock it down a bit for 4".
Old 08-14-2007, 08:20 PM   #4
Teetorbilt's Avatar
Pretty easy calc. How much do you usually get out of a gal? You'll get 3 times the sq. ft. for 4".
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 08-14-2007, 08:22 PM   #5
Trade: Painter
If you use 400 sq ft (most gallons I use) the math would be:
400=.3333x
x= 1200 linear feet, assuming application is at the what ever wet mil that manufacturer has in mind.
DeanV is online now   Reply With Quote
Old 08-14-2007, 08:22 PM   #6
rws
Trade: paint contractor
Send a message via AIM to rws
Four inch by 800 lin ft = 267 sq ft ? a gallon over preprimed may cover 350 sq ft
rws is offline   Reply With Quote
Old 08-14-2007, 08:25 PM   #7
Sarcastic Prick
Trade: Paint and Floor Covering Retailer
I'd say about 600-700 ln ft based on real experience with it. We paint 4" baseboard for an apartment complex on a regular basis. We use P&L RedSeal Semi-gloss and get roughly 600-700 ln ft. We roll it on with a 3/8" Pro-DooZ and immediately brush back over it with a loaded brush. So we may be putting more on this way that you would normally consider one standard coat.
gideond is offline   Reply With Quote
Old 08-14-2007, 09:39 PM   #8
Chief Toilet Mover
Thanks. Sounds like I might use 500 ln ft per gal to start with and then keep track of what we get and adjust if necessary.
Old 08-14-2007, 09:59 PM   #9
Estimator
DavidNTX's Avatar
Trade: Estimating
Mike, just in case you or anyone else doesn't understand the mathematics behind figuring that out, I will try to explain. That way you can figure your coverage regaqrdless of the width.
Let's say the paint we are using covers 300 square feet per gallon on a smooth surface. That is 300 areas 12" X 12". If the surface is only 4" wide then 12"/4"=3. You will get 3 times the coverage so 300 X 3 = 900. If the paint coverage was 400 SFPG then you would get 1200 LF 4" wide. For a 1X6 using 300 SFPG would be 600 LF and 1x6 using 400 SFPG would be 800 LF.
Don't forget other factors, if 1 edge of the 1x4 needs to be painted that adds 1 more inch to the 4 inches. 12"/5"=2.4 300X2.4=720 and 400x2.4 would be 960 LFPG.
Another factor would be waste. If you are spraying the 1x4 using a 6" fan then you will have a waste facor to consider. Using a 12" fan would essentially be the same square footage rate.
I hope this might help someone somewhere someday.
David
DavidNTX is offline   Reply With Quote
Old 08-14-2007, 10:33 PM   #10
Chief Toilet Mover
One other question, any type of sprayer that would be good for small projects?
We recently built a small 3 shelf insert to go in a wall, about 9 inches deep by 36 tall, 25" wide. Built it out of MDF and had to paint it white. We're not painters and the results were good, but not flawless. I have a Graco sprayer, but there was no way in hell I was going to break that out for this little thing.
Is there some sort of sprayer that you could shoot like a pint or a quart out of that is fast, easy to clean and simple to use?
Old 08-14-2007, 10:47 PM   #11
Remodeler Extraordinare
A.W.Davis's Avatar
My painting subs mainly use these sprayers(440i)...I am half tempted to get one for myself!
http://www.paintsprayerslv.com/Titan/ix_series.htm
They typically spray all of my new doors I install and occasionally spray the walls and cielings on larger jobs I am at, where the homeowner is wanting the whole house painted.
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline   Reply With Quote
Old 08-15-2007, 12:27 AM   #12
Chief Toilet Mover
Yep, I've got a sprayer pretty much like that one. It would take me 3 minutes to spray what I'm talking about and 30 minutes to drag it in and out of the trailer, set it up and clean it. I'd like something that takes less than 5 minutes to set up, take down and clean.
Old 08-15-2007, 07:19 AM   #13
Years ago, we supplied some air-brushers with t-shirts. A double action Pashe can give you a pencil thin line to I don't know maybe 1/2" line by just sliding the control back and forth with the index finger. Don't know if one of these would work for the kind of paint being used. You might want to check it out.
boman47k is offline   Reply With Quote
Old 08-15-2007, 07:53 AM   #14
...jammin
slickshift's Avatar
Trade: Rock Disciple
Yup
My favorite is the little gas powered cup sprayers
It's a little mason jar type deal, that you hook up a little CO2 cartridge to
I don't have a pic or name off-hand....the paint store should have them
They are very handy for those ten minute spray jobs
Are cheap enough to be disposable if you need to sacrifice it, but super easy to clean and keep
Take up virtually no space in the van
Well worth it (IMO) to keep one and a few CO2 carts (actually, I'm assuming it's CO2-could be something else) on hand
I often find myself breaking one out for small jobs where a little spray would really help (like under deck lattice staining)
Comes in handy
Signature Quote
slickshift is offline   Reply With Quote
Old 08-15-2007, 07:56 AM   #15
...jammin
slickshift's Avatar
Close:
Signature Quote
Old 08-15-2007, 12:56 PM   #16
Sarcastic Prick
Prevail!
Their logo should be "One in ten actually works!"
Old 08-15-2007, 01:19 PM   #17
rws
Originally Posted by gideond View Post
Prevail!
I have never had any luck with them.
Old 08-15-2007, 09:08 PM   #18
...jammin
slickshift's Avatar
Prevail!
Ha ha ha...
I'll remember that one, and stay away from that name
The shop has some other brand
Don't recall having any problems with them
Signature Quote
Old 08-15-2007, 09:34 PM   #19
MODERATOR
ProWallGuy's Avatar
I like the Preval sprayers, and keep one in the tool box at all times. Sure, I've had a couple duds, but if you thin the material properly, they work fine, for me at least. And the time they have saved me more than make up for the bad ones.
Old 08-16-2007, 05:54 AM   #20
Sarcastic Prick
I use to sell them here at the store. We could literally have a case of the aerosol cans come in and go through the whole case for a customer before finding one that would actually spray at all.
Cost of a Square Footage Jake82 General Discussion 5 09-04-2006 11:48 PM
Linear Foot Pricing deno99205 Finish Carpentry 1 06-28-2006 11:47 PM
measuring stonework square footage kermmonk Construction 6 06-20-2006 08:23 PM
Maximum coverage sprinklers snapper21 Landscaping 6 06-20-2006 02:26 PM
Square footage cost/bidding vtgaetano Carpentry 14 03-19-2006 12:47 PM
