Old 04-29-2006, 09:01 PM   #21
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by lornmastro
...why wouldn;t you paint the baseboard first, tape it, then paint walls, remove tape and wal-la!! no splatter on baseboard...
Because I don't tape and I don't splatter
Signature Quote
slickshift is offline   Reply With Quote
Old 04-29-2006, 10:38 PM   #22
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
For me, I do ceilings, then I like to do a first coat on the trim, followed by two coats on the wall. This way I can cut my wall to the trim instead of trim to the walls. When walls are done, I do a final coat on the trim which negates and sprinkles. I've made it a rule to wipe the top of baseboards with a damp cloth after rolling each wall to prevent a texture from spatter...drips get wiped up right away. No masking, no sprinkles, no muss, no fuss.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 04-30-2006, 12:30 AM   #23
Again, a professional painter can cut a straight line from a wall to trim or from trim to a wall. You cut in and I'll cut out!
Woz the Painter is offline   Reply With Quote
Old 04-30-2006, 09:56 AM   #24
Dripless
Trade: Painting and exterior wood care
I think its easier to cut wall to trim because you can have the stability of the whole brushs footprint on the wall instead of just the 3/4 inch surface you have when cutting trim to wall. I think you can just move faster with more confidence that way.
Dale is offline   Reply With Quote
Old 04-30-2006, 07:40 PM   #25
Trade:
I use to do it as follows: Ceilings, walls, trim.
then for some reason years back - we needed to get the trim done right away. so we went Ceilings, trim, walls. And found that to be much easier. Especially since when you are waiting for the first coat of trim to dry - you can at least roll your first coat of wall paint and not cut in. By the time your trim is done - all you have to do is cut twice and roll one last time.
I had job where I ended up spraying all the trim. Other subs got in my way - so before I could get on a second coat on the trim - I just Started painting walls in - cutting and rolling. Later I used a tool that dispenses paper along with tape and taped around all the baseboards and trim - so I could shoot on a second coat of the oil trim paint. Worked flawlessly. And Makes me wonder if I am going to spray trim if I should go back to Ceilings - Walls - Trim. And just tape out all the trim and spray the dickens out of them. One guy I knew who was a sprayer said he did it that way.
-plainpainter
PlainPainter is offline   Reply With Quote
Old 05-20-2006, 10:22 AM   #26
Trade: Painter/ plasterer
hmmmm
Lornmastro, I don't think anyone has answered ur question about why leave the skirting boards ( you guys call them base boards ) till last.
When I'm painting a house or a room for that matter....I leave the "baseboards" till last in order to keep my paint clean.
It doesn't matter how well you sweep or brush away the dust/dirt.....you will inevitably get contamination.
For this reason I do the windows/ door frames and architraves first...then go back around the house and do the baseboards/skirtingboards.
Hope this helps,
Mike.
adagio_adeux is offline   Reply With Quote
Old 05-20-2006, 09:42 PM   #27
Pro Painter
AAPaint's Avatar
Hope this helps,
Mike.
Very good answer...I totally over looked the fact that he was asking why do baseboards last. This is something we do naturally without thinking about it....when it comes trim time I won't touch doors, sills, casings, etc with a brush that I just used for baseboards....no way.
-AAPaint
Jacksonville, FL.
-James Madison
Old 05-28-2006, 11:51 AM   #28
painter in florida
Trade: painter
Originally Posted by ProWallGuy
Ceiling, trim (minus baseboards), walls, then baseboard.
imo this is it, no need to cut things twice or paint over and this way you can spray your trim 10x faster then spray/sheild walls or cut/rool walls. and you prime trim most cases with your ceil paint.
amcline is offline   Reply With Quote
Old 05-29-2006, 12:44 AM   #29
General Contractor
Trade: General Contracting and Painting
Ceiling, walls, trim
but after reading the other responses I may try ceiling, trim, wall
jensenconstruction is offline   Reply With Quote
Old 03-18-2007, 07:35 PM   #30
Trade: painting and pressure cleaning
ceiling cutin wall tim
Robert S is offline   Reply With Quote
Old 03-18-2007, 07:56 PM   #31
Workaholic's Avatar
ditto
Sean
Workaholic is offline   Reply With Quote
Old 03-18-2007, 09:11 PM   #32
My custom title
Brushslingers's Avatar
Depends.. but most, ceilings trim (first coat base) walls, final base.
Benn
Originally Posted by Brian
Brushslingers is offline   Reply With Quote
Old 03-18-2007, 09:49 PM   #33
habitual line stepper
Walls are always easier to cut in IMO. So I say ceiling, trim and then walls.
DPainting is offline   Reply With Quote
