Which Comes First?
Old 04-28-2006, 08:19 AM   #1
HandyAl's Avatar
Trade: Handyman
Which Comes First?
OK painters. How do you paint a room?
Wall, ceiling, trim
ceiling, wall, trim
trim, wall ceiling,
etc, etc....
HandyAl is offline
Old 04-28-2006, 09:51 AM   #2
IJS's Avatar
Re: Which Comes First?
ceiling, trim, wall
IJS is offline
Old 04-28-2006, 10:02 AM   #3
Administrator
Nathan's Avatar
Trade: Admin
ceiling, wall, trim
I guess it depends on how good you are at cutting a straight line. I like to roll everything out and then cut in the trim at the end with a nice straight line.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
Old 04-28-2006, 12:11 PM   #4
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Ceiling, trim (minus baseboards), walls, then baseboard.
ProWallGuy is offline
Old 04-28-2006, 12:16 PM   #5
Teetorbilt's Avatar
I was taught to start at the top and work down. Ceiling, trim, walls. I like to do all of the cut-in first and then roll, it reduces the brushmarks next to the trim, ceilings, etc.
Albert Einstein
Teetorbilt is offline
Old 04-28-2006, 12:26 PM   #6
Remodeler
MinConst's Avatar
I've always done ceiling, walls, trim. But after reading this thread I may try doing the trim before the walls. Seems like it would be easier to cut in the walls rather than the trim.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 04-28-2006, 12:27 PM   #7
ProWallGuy's Avatar
Exactly.
Old 04-28-2006, 12:38 PM   #8
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
ok....and now i know this might be a stupid question but if you do the trim then the wall don't you splatter on your freshly painted trim?? or do you then tape up the trim?? thanks
lornmastro is offline
Old 04-28-2006, 12:56 PM   #9
ProWallGuy's Avatar
The only splatter we have is going down, hence waiting on the baseboard til last.
And also, using top-quality paints, and good roller covers eliminates 90% of spatter.
Rolling BM Regal Matte with Wooster 50/50's, spatter is almost zero. I don't tape off for anything.
Old 04-28-2006, 12:58 PM   #10
Administrator
Nathan's Avatar
Trade: Admin
Not for me at all... I guess I'm just strange.
Nathan
Nathan is offline
Old 04-28-2006, 01:36 PM   #11
Painter
camaroman2125's Avatar
Trade: Painter
I guess that makes me strange also. I have always found it easier to cut in the trim to the wall than the wall to the trim. Don't ask me why cause I don't know.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is offline
Old 04-28-2006, 01:40 PM   #12
Administrator
Nathan's Avatar
Trade: Admin
I know why for me... its called gravity. Paint drips down onto the trim. Of course I guess that makes me unprofessional to say so.
The vertical trims I can go either way on.
Nathan
Nathan is offline
Old 04-28-2006, 01:52 PM   #13
...jammin
slickshift's Avatar
Trade: Rock Disciple
I don't tape and I don't splatter, but I usually do the walls before trim anyway
Originally Posted by ProWallGuy
...using top-quality paints, and good roller covers eliminates 90% of spatter.
Ditto
Ditto
ceiling, wall, trim
That's usually how I do it
There is a certain logic to that
I don't recall trying it that way though
Maybe on a crew years ago it worked out that way
But not on purpose that I recall
....I'm just strange.
....perhaps that should be another thread all by itself
Lol...(j/k)
(hey your at the helm of this boat full of nuts, you must be a little off the beaten path lol)
Signature Quote
slickshift is offline
Old 04-28-2006, 03:19 PM   #14
Woz the Painter's Avatar
Ceiling, walls, then trim....except on a large office build out where if you can shoot all the frames first, then come back and prime and paint the sheetrock.
Woz the Painter is offline
Old 04-28-2006, 04:54 PM   #15
phinsher's Avatar
Trade: Paint and wallpaper
Ceiling, trim, walls, final coat on baseboard.
Much easier to clean flat wall paint from the shiny trim then it is to clean trim paint from the flat wall paint if ya mess up.
Plus how ya gonna cut in the top of the wall while the ceiling paint is still wet? Paint that ceiling, while it dries paint the trim one wall at a time. Then start cutting in walls one at a time wherever you started panting trim. Well, thats what works for us, but I know plenty of painters that think i'm nuts.
phinsher is offline
Old 04-28-2006, 10:47 PM   #16
Painting Contractor
DelW's Avatar
Trade: Painting Contractor
For me its all about the visual aspect. Its easier to paint trim 1st, then the wall, it makes it alot easier to cut a straight line on the wall in tight quarters than try to get the edge of a door casing in a corner. Hope that makes sense.
DelW is offline
Old 04-28-2006, 10:55 PM   #17
Remodeler
lxdollarsxl's Avatar
Trade: Remodeler/Painter
Send a message via Yahoo to lxdollarsxl
Ceiling- trim- cut in -walls- base, and a little trick i learned years ago i carry 2 - 4 feet long 12 inch wide ply which i lay along base to prevent any splatter and move them as i get along the wall.
lxdollarsxl is offline
Old 04-29-2006, 01:30 PM   #18
lornmastro's Avatar
ok....i'm sticking my neck out here sooo be kind and patient with me...lol...as i have said before i am self taught with no mentor...but....gulp....why wouldn;t you paint the baseboard first, tape it, then paint walls, remove tape and wal-la!! no splatter on baseboard, real clean lines,no need for boards,done!! thanks ahead of time for not hitting me with spitballs ....lol
Old 04-29-2006, 05:24 PM   #19
phinsher's Avatar
lornmastro, we used to do it just the way you described. Paint ceiling, paint trim, mask trim then paint walls and demask. It sure made for some straight lines, and no spatter. The problem is, it takes longer and it costs more.
phinsher is offline
Old 04-29-2006, 05:58 PM   #20
A professional painter shouldn't have to mask things off, other than vinyl base or to protect objects when spraying. Masking everything is for homeowners!
