And just to stave off an argument, let me explain why this is the best way.
First, acid staining is a one time deal. There is no do-over, and if you do not protect it, it WILL show signs of traffic in a relatively short amount of time.
Second, anytime you seal a concrete floor, you are creating a maintenance issue. It will have to be redone, usually yearly or every other year commercially and every 3-5 years for residential use. Stripping and resealing is an expensive and painful process. Simply by using a good quality wax and maintaining it, which is an easy and normal process, you will never have to redo the stain or the sealer.
