Old 04-14-2009, 11:29 AM   #1
Trade: Painting & Wallpaper
Cleaning of smoke damage
Hi everyone. Have a couple jobs where wood fireplaces caused very minor smoke residue on drywall. I did not see any residue(ran fingers across walls in different areas of house). Insurance company says they are including (wash ceilings/walls) in their appraisal of damages. Question is -
1. What is going rate for wash drywall?
2. What products (aside from tsp) are out there?
3. Methods for applying cleaner to drywall do you use?
We have not had much fire/water damage jobs in last few years so would be good to know what insurance companies will pay for this line item!
Have also thought of applying tsp/water solution with airless (very light spray) and then sponge mop dry!
As I said, you cannot see any smoke residue but can smell it (mainly carpets that will be replaced).
Tahoe Painter is offline   Reply With Quote
Old 04-14-2009, 10:37 PM   #2
Trade: Painting, flooring
I too had the airless tsp idea. my local rep talked me out of it. Just use a pesticide pump sprayer.
sparehair is offline   Reply With Quote
Old 04-15-2009, 01:51 AM   #3
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Not joking here, but there are some sponges I call magic sponges that remove rhe smoke residue, check with the restoration insurance working crew for an exact name for it, then stain kilz the areas.
Mr. Mike is offline   Reply With Quote
Old 04-15-2009, 03:32 AM   #4
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
And be sure to use the organic kilz
chris n is offline   Reply With Quote
The Following User Says Thank You to chris n For This Useful Post:
sparehair (04-15-2009)
Old 04-15-2009, 10:45 AM   #5
why would rep talk you out of using airless as this application would be alot faster than pump sprayer?
Old 04-15-2009, 11:22 AM   #6
Organic Painter
Mr. Mike's Avatar
use the sponges...
Old 04-15-2009, 12:28 PM   #7
Organic Painter
Mr. Mike's Avatar
Me and you Chris to the top.
Old 04-15-2009, 12:32 PM   #8
Trade: Prep Nazi
Originally Posted by Mr. Mike View Post
use the sponges...
Best thing ever invented for smoke damage, I can't remember what they're called though..
StefanC is offline   Reply With Quote
Old 04-15-2009, 12:55 PM   #9
Organic Painter
Mr. Mike's Avatar
Measures: 1-3/4" x 3" x 6"
Known for cleaning in the fire restoration field and very popular to remove soot and dirt from any surface you do not want to get wet including books & paper documents, computer screens, car dashboard, lamp shades, pictures, paintings, and much, much more!
This is an exceptional sponge and a must for soot removal. Use it dry to clean any surface - it actually absorbs a tremendous amount of soot/dirt into the cells of the sponge. Made of volcanized natural rubber. It is completely safe and non-toxic. These are known as chemical sponges
Mr. Mike the helping helper.
Old 04-15-2009, 07:00 PM   #10
1. we all know that masks leak and he was not of the opinion that breathing atomized tri sodium phosphate or its substitute would be very good for your lungs. See citation below...
2. you're not supposed to run chlorine through an airless and that was my first question ie will the basic (i believe tsp is an alkaline salt if I'm not mistaken) tsp solution corrode the metal like bleach will? He wasn't sure but thought I was on the right track.
3. It's not faster. You can cover a lot of ground quickly with a $10.00 pesticide sprayer and not spend any money on packings, tips, lube etc. Everytime that piston goes up and down it costs money.
From wiki...
Alkalis are all Arrhenius bases, which form hydroxide ions (OH-) when dissolved in water. Common properties of alkaline aqueous solutions include:
Moderately-concentrated solutions (over 10-3 M) have a pH of 10 or greater. This means that they will turn phenolphthalein from colorless to pink.
Concentrated solutions are caustic (causing chemical burns).
Alkaline solutions are slippery or soapy to the touch, due to the saponification of the fatty acids on the surface of the skin.
Alkalis are normally water soluble, although some like barium carbonate are only soluble when reacting with an acidic aqueous solution.
Acids and alkalis are measured on a pH scale
Alkalis are commonly found in household cleaners like bleach
The Following User Says Thank You to sparehair For This Useful Post:
skyhook (11-01-2009)
Old 04-15-2009, 07:08 PM   #11
That reminds me. The first chemical weapon used in modern warfare was chlorine gas. Blew a hole right through the canadian lines. The german's had no idea how effective the gas would be and failed to capitalize on the surprise and shear terror the attack induced. Interestingly, I remember this from my excellent high school history teacher Mr. Bachlund, that there was a young chemist among the canooks who realized that the urea in urine would react with the chlorine and neutrilize it. So the guys who were left, the ones who didn't drown in their own blood, survived by pissing on their socks and tying em around their heads.
Old 10-22-2009, 09:23 AM   #12
TheCleaningDoc's Avatar
Trade: Exterior Building Cleaning
Sponges are great but when you have an entire garage and part of a kitchen to do they suck. Too much time involved.Going to test TSP on the walls today. Popcorn ceiling is history.
The Cleaning Doctor
Pat Motz 931-933-5421
TheCleaningDoc is offline   Reply With Quote
Old 11-01-2009, 08:10 PM   #13
Kuba's Avatar
Trade: Painting - Restoration
sounds to me as tho you shouldnt be doing fire restorations...
also sounds like the insurance company is going to love you! =)
hope you have a good lawyer....
Kuba is offline   Reply With Quote
Old 11-01-2009, 08:32 PM   #14
Didn't say I was doing fire restoration. Just cleaning and getting ready for the guys to come in and refinish. There is one person that I do trash outs for because they are a friend. No fire damage just soot all over the walls and ceiling. Oh well we are past that one now.
The Cleaning Doctor
Old 11-01-2009, 08:40 PM   #15
Kuba's Avatar
jolt or tsp
Roof Cleaning Pictures Wanted !! Roof Cleaning Pressure Washing 3 10-24-2009 03:14 PM
Fire and Smoke Damage? kdub1777 General Discussion 2 07-02-2008 08:33 PM
smoke damage bill02 Remodeling 7 11-07-2006 09:56 PM
Cleaning Smoke Stained Masonry Brickie Masonry 11 09-07-2006 10:23 AM
Smoke Damage? CoastalCoatings Painting & Finish Work 13 02-16-2006 10:22 PM
