Leaving you pump under pressure especially with thinner in it is a bad idea. I knew this guy who left his pump under pressure on a job and his hose got a pin hole leak while no one was on the job. When you get a leak like that it spews this thin stream of whatever is in your pump for yards. He left paint in his pump. When he showed up the next morning paint was over everything like silly string. I was in the middle of spraying an exterior and set my gun down to move a ladder or something and I heard this loud shhhhhhhhhhh sound and I turned around and there is my hose and gun flying 40 feet this way and that. And it was a fairly new hose. Now if that had happened while I was at lunch
And its not just the hose that can fail. If for instance you leave your pump under pressure with thinner, in a garage with any open flames such as hot water heaters, ceiling hung natural gas heaters ect and your pump is under pressure and gets a leak which happens alot more than you'd think, and shoots over that flame, well you got yourself a problem. And if you got kids around old enough to figure out the gun lock and they get a eye full of thinner or worse injected. Leaving pumps under pressure .....not good
