Old 09-23-2009, 11:42 AM   #1
JonM's Avatar
Cleaning and Marking Cabinet Doors...
What do you guys use to make kitchen cabinet doors you have removed if you are going to reseal them?....Also what do you use to clean years of kitchen grease and dirt off before sealing...these are vainer doors with poly or varnish on them.
New cabinets aren't an option, this is a couple in their 80's on somewhat of a fixed income...and believe me if I could have convinced them to use someone else to paint them I would have. They trust me, I have done allot of work for them over the years. It's my good deed for the decade...
JonM is offline   Reply With Quote
Old 09-23-2009, 05:01 PM   #2
Trade: interior trim
I have always cleaned with mineral spirits and 4 o steel wool. Final cleaning with alcohol and a rag.
If they are to be re varnished I'll use Minwax Wipe on Poly(after testing a spot)
mikeswoods is offline   Reply With Quote
Old 09-23-2009, 05:05 PM   #3
I assume you are smart enough to realize this is flammable.
Ha Ha,Good luck-Let me know how it works.--MIKE
Old 09-23-2009, 05:16 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
Use TSP
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline   Reply With Quote
Old 09-23-2009, 07:34 PM   #5
Steve
Trade: Remodeling and Custom Cabinets
If they are Euro Hinge, I mark each door by a number written in one of the hinge holes left when the hardware is removed. After writing the number, put masking tape in the hole to cover the number. After painting, take the tape off. Install the hinges and hang that door then move to the next one.
BACKWOODS is offline   Reply With Quote
Old 09-23-2009, 11:05 PM   #6
New and Remodel Carpentry
cooks's Avatar
Trade: General Contractor/Remodelor
You can also do what backwoods said with regular hinged doors. Bul i would just pull the hinge and use a sharpie to write the number underneath where the hinge will be reinstalled.
cooks is offline   Reply With Quote
