Cleaning A 5-Gallon Grill?
Old 10-08-2006, 02:13 PM   #1
metomeya's Avatar
I have dried latex on it.
Is there anything I can soak it in to remove that latex paint that won't remove the galvanization?
I've tried denatured alcohol on a metal try and it rusted right up.
I looks like I could keep using it without removing the paint......
Do the pros just buy new ones for every job?
metomeya is offline
Old 10-08-2006, 02:17 PM   #2
mdshunk's Avatar
Re: Cleaning A 5-Gallon Grill?
EZ OFF oven cleaner (the original yellow can) will make latex fall off like melted butter. Spray 'er down good and wait overnight. Spray it off with a hose. It's basically caustic (lye) solution.
mdshunk is offline
Old 10-08-2006, 02:23 PM   #3
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
A bonfire works really well also ,same for 1 gallon paint pans.....
painterofeveryt is offline
Old 10-08-2006, 02:26 PM   #4
mdshunk's Avatar
Yeah, but you need to wait until 'Earth Day' to use that procedure.
mdshunk is offline
Old 10-08-2006, 04:21 PM   #5
My custom title
Brushslingers's Avatar
I don't remove the dried paint from screens.... in fact, I like em better coated up.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 10-08-2006, 07:52 PM   #6
Woz the Painter's Avatar
What's a grill? Is it on your car?
Woz the Painter is offline
Old 10-08-2006, 09:03 PM   #7
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Same here.......I've got one you can barely see light through. good thing I just bought 2 more the other day.
Rich
Richard is offline
Old 10-08-2006, 09:05 PM   #8
Teetorbilt's Avatar
Woz, a grille is on your teeth. I'm old and even know that much.
Albert Einstein
Teetorbilt is offline
Old 10-08-2006, 09:19 PM   #9
mdshunk's Avatar
You guys are all mixed up. THIS is a 5 gallon grill:
mdshunk is offline
Old 10-08-2006, 09:51 PM   #10
Teetorbilt's Avatar
Grille.
Even an old white dude from the south knows this.
Albert Einstein
Old 10-09-2006, 09:26 AM   #11
AFI's Avatar
Trade: Paint Contractor
AFI is offline
Old 10-09-2006, 07:56 PM   #12
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
There goes lunch...
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-09-2006, 08:09 PM   #13
747's Avatar
Have you tried steam?
747 is offline
Old 10-09-2006, 10:25 PM   #14
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
One of my helpers spilled a quart of latex paint on a customers driveway a few years ago. We tried laundry detergent and water, lots of water. Then we got a goo-be-gone type of product that removes dried latex paint. Come to find out, it removes asphalt, it even says it on the can....if I only read it before we killed their driveway. The driveway was brand new!
dougchips is offline
Old 10-09-2006, 10:25 PM   #15
Pro Painter
AAPaint's Avatar
Nah....use em till their all clogged up and throw em away. They are less than $2 a piece. We put them down in the paint until we finish the job then we rinse them off which usually only cleans the bottom half and just use em up. At $45/hr it's not worth the time to clean them more than that.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-09-2006, 10:40 PM   #16
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Every summer I throw 20-30 of them in a big metal wash tub, and light it up. Knock em off with a hammer, and your good to go. Sometimes I'll give them a shot of rattlecan primer before using them again.
Phuck the earth, save yourself!
ProWallGuy is offline
Old 10-09-2006, 11:59 PM   #17
Flawless Finish's Avatar
Where?
Flawless Finish is offline
Old 10-10-2006, 09:21 AM   #18
Pro Painter
AAPaint's Avatar
SW paint store....
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 10-10-2006, 11:19 PM   #19
SW paint store....
Thanks...
Old 10-11-2006, 08:41 PM   #20
Joewho's Avatar
Trade: Painter
wit, humor, pictures and painting advise. What a good forum.
Joewho is offline
Roof cleaning Barry M Roofing 33 09-26-2011 01:36 PM
Drain cleaning Moonray Plumbing 14 12-25-2009 11:41 PM
drain cleaning the_turd_man Plumbing 13 02-07-2007 05:26 PM
Cleaning the gas grill Teetorbilt Off Topic (Non Trade) 10 04-24-2006 08:07 PM
