Clawfoot Tub Exterior
Old 09-04-2007, 08:31 AM   #1
Sauna & Steam - Remodelin
Flacan's Avatar
Trade: Remodeling / Sauna & Steam
I know this sounds like a HO question, but since it fits within the scope of my work, I'll ask it here.
My wife purchased a clawfoot tub, the interior of which is slightly worn, but in good enough condition, that it doesn't need redoing. The tub itself is in good shape, and doesn't need any repairs.
The exterior surface of the tub is the wrong color, and she will be painting it prior to us installing it in the master bathroom of our addition (btw- I'm the contractor on the job).
Any suggestions on how she (she's the "painter" - has a good eye and pretty good hand-eye coordination, but lacks some knowledge) should go about this. She's adept at using sanders, grinders, epoxy, hardeners, etc, so please don't make the answer applicable to your average HO.
Although we don't own a sprayer, I have sprayed some ceilings, walls, & automobile parts long ago. I also am adept with stone work such as granite counters, marble fabrication, etc, which might help here - probably not?
Thanks in advance!
Raimo Kumpulainen
Those who don't remember the past, are condemned to repeat it.
Flacan is offline
Old 09-04-2007, 09:19 PM   #2
mikenewman@fron's Avatar
Trade: Painter
Re: Clawfoot Tub Exterior
I have had good luck with any good oil base semi or gloss paint. sand with 220 and roll it with a fine nap or worn out mini roller. I would add a little Penetrol to increase leveling. I have used this on refrigerators, freezers, dishwasher fronts. It works great. Mike in Moab
mikenewman@fron is offline
Old 09-05-2007, 01:16 AM   #3
reveivl's Avatar
Trade: Renovations
I scored a claw foot out of someone's back yard years ago, the interior was in fine shape, but the outside was a mess. I took it to a sand blaster and he blasted it and primed it for very little ca$h. It's still in my bathroom today and looks like the day it was made.
reveivl is offline
Old 09-06-2007, 09:38 AM   #4
Flacan's Avatar
Thanks guys!
Raimo Kumpulainen
Flacan is offline
Exterior Wall Sheathing in B.C., Canada? wallmaxx Framing 9 01-21-2008 01:10 AM
Weatherproof, stainable exterior jambs MKamis Finish Carpentry 1 07-28-2007 12:04 PM
Help with exterior painting!!! tripster Painting & Finish Work 12 07-11-2007 11:02 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
New Exterior Columns Richie-C Painting & Finish Work 5 04-27-2006 10:50 PM
