Trade: Painter
Cinder Block Walls, Block Filler And A Leak...question
We've got about a 40,000 sq ft building with block wall in the warehouse.
We've just about got a coat of block filler on the walls. Now it looks like there is a leak from the roof (standing water, gutters clogged) that may be getting water in between the blocks on one back side of the warehouse. I've spoken to about 4 very well versed painters and 3 of the 4 tell me there's no way the paint will cure correctly and it will peel off. I believe these guys. The one guy who tells me otherwise is my dang foreman. My foreman has a ton of experience painting warehouse block walls and he swears to me there will not be a problem. He says a good layer of block filler and a good finish coat will do the trick. Is there any reason to believe the leak won't cause the paint to peel off? My foreman says the water may come through, but it will not push the paint off the block. I don't believe him. Should I? |
#2 | |
Professional Painter
Trade: Owner/Operator
Re: Cinder Block Walls, Block Filler And A Leak...questionQuote:
Good luck Sean
Rich |
#3 | |
My custom title
Your screwed, it will create a problem, call my dad at benchmark fixture and he can lead you through a fix....
Benn Quote:
Not sure, but have read on labels of block filler 5's, that if surface is to dry, shoot some water on it for better penetration before block filling. Not saying surface should be filled during a downpour or with water running on it, just that if it is damp you should'nt have a problem...
#5 | |
Trade: Painter
Re: Cinder Block Walls, Block Filler And A Leak...question |
MFWIC
Trade: house painter
Ask your foreman:
if you DO seal the block, then paint, WHERE will the water go ? How many layers of paint will it take to support the weight of the water? I DO KNOW simple groundwater will lift epoxy up off a prepped concrete slab in the most horrible looking blisters you EVER saw! You need to paint the OUTSIDE of a boat 1st ... If you can't stop the water leak, best to apply just 1 lite color coat over the block (when dry) and let the water continue bleeding thru. r |
#8 | |
Epoxy Dude
Trade: Industrial Coatings & Linings
From my perspective... you have not given anyone here enough information to answer your question with any certainty. So far, your foreman is the only one who knows what is happening. If you don't trust this guy... FIRE HIM! What is the point of having anyone working for your that you don't trust?
First... are we supposed to assume that you are using an acrylic block filler? Was the block dry when you applied it? How long did it have to cure before the water leak happened? What is the topcoat chemistry going to be? Quote:
Sean, I don't know if the next thing I say will help or not. But, are you looking at the big picture? What if you topcoat it and it DOES fail? Obviously, you can't be responsible for a roof leak. I know we all want to do the best job we can... but... sometimes things are out of your control and not your responsibility? Is this?
Some things just shouldn't be mixed... like... Kids & Paint http://www.wolverinecoatings.com/Pic...kids&paint.gif |
#9 | |
MFWIC
Trade: Project Manager and Builder
Dap 1 Masonry Bonding Liquid Use as a concrete glue and use it in cement, plaster, waterproof cement paint, stucco and floor leveling compounds. Provides maximum adhesion and superior results. Interior/exterior. As the others have stated a bonding agent.
| Cinder block | Joewho | Painting & Finish Work | 15 | 03-11-2007 08:11 PM |
| cracking cinder block walls | Lofty Notions | Remodeling | 1 | 05-05-2004 12:51 AM |
