Check Out The Latest Rankings Of Interior Paint From Consumer Reports Mag.
Old 08-05-2006, 10:47 AM   #1
Dorman Painting's Avatar
Trade: Painting Contractor
top five for low luster
1) Behr, premium plus satin enamel (Home Depot)
2) Kilz Casual Colors Satin ( Wal Mart)
3) Valspar American Tradition (Lowe's)
4) True Value E-Z Kare
5) Dutch Boy Home(Wal Mart)
Behr also was the leading paint in the flat and semi gloss categories. I'm baffled by these results, when I think of Dutch Boy I'm thinking cheapola. Kilz?? Hell I've painted for almost ten years and didn't realize they had anything outside of a good primer. These results must be from a lack of true understanding of paint performance. I'm a Sherwin Williams man, and while they have cheap products, most of their stuff is good to excellent. SW got low grades in the three major categories, always towards the bottom of the barrell. Is Behr really that good? What do you all think of these results?
Dorman Painting is offline
Old 08-05-2006, 11:00 AM   #2
My custom title
Brushslingers's Avatar
Re: Check Out The Latest Rankings Of Interior Paint From Consumer Reports Mag.
Sounds like sales volumes to me.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-05-2006, 12:19 PM   #3
reveivl's Avatar
Trade: Renovations
Are they saying it's better paint or just better value? If the criteria involves cost then I can see how the premium paints might not make it on the list.
reveivl is offline
Old 08-05-2006, 12:38 PM   #4
Moderator
Double-A's Avatar
Ya, that's sorta like reviewing full-sized pick-up trucks for under $14,000 MSRP. Slim pickings.
Our painters prefer BM or SW paints over anything else. I don't argue. If they're happy and the client is happy, I'm happy.
New York Times, July 20, 2006
Double-A is offline
Old 08-05-2006, 01:08 PM   #5
...jammin
slickshift's Avatar
Trade: Rock Disciple
First off, once again that is not the latest test
It's a re-hash and re-package of their previous testing
Secondly, the "test results" are for DIYers, and use DIY criteria for their testing
DIY criteria is significantly different then professional criteria
For example, DIYers will flip if they open the can of paint and the wet in-the-can paint doesn't match the swatch...they are back to the store
I enjoy and support the CU and their magazine CR
They are full of interesting information
When they say that certain home air filters spew more ozone then clean up the air I listen
When they say the new 28volt cordless drills melt their internals driving lag bolts I take note
They certainly do use the Scientific Method (note caps) for repeatable quantifiable tests and test results
However:
When I am buying a new computer I check the ratings from PC World, not CR
When buying a vehicle, I may see what CR says, but will defer to Car & Driver or Autoweek
When CR does not recommend any hammer drills (none!) because of the noise they make, I basically agree with them
For most Homeowners a hammer drill is not the right tool
But if you are building decks....you are going to need one
My point in regards to CRs paint testing is:
CR does not use professional painters, or professional painting criteria to evaluate paint
They certainly use a scientific method of evaluation, but look at the little boxes with the points they use to rate the products
There's maybe one or two testing areas out of seven (going from memory here) that mean anything to a professional painter
....and many other areas that are very important to me and you that aren't even touched
In general I find the CR test results interesting
Sometimes even helpful....but the paint testing baffles me
Signature Quote
slickshift is offline
Old 08-05-2006, 01:17 PM   #6
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
CR suggests paint brand XX is blah blah blah.
ProWallGuy is offline
Old 08-05-2006, 02:19 PM   #7
Pro Painter
AAPaint's Avatar
That makes me laugh every time I hear it.....
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 08-05-2006, 02:28 PM   #8
AllPro_Painting's Avatar
I use BM or SW paints over anything else. My Co. only stands buy top qulity. that means from the caulk to the finnish
AllPro_Painting is offline
Old 08-05-2006, 05:30 PM   #9
However:
Here's the criteria they used, hiding performance which certainly applies to us. Hiding reflects how well two coats cover a contrasting color, whether dark over light or light over dark. Surface smoothness which they say indicates an absence of roller marks when the paint drys on the wall. This one shouldn't pertain to us because hopefully we're using proper technique's. Resistance to staining which shows how well paints resist a greasy stain. This one really doesn't apply to us as much IMO. If people get grease on their walls that's not my fault. Another area they test for is scrubbing which shows how well paint holds up to an abrasive cleaner. Gloss change is another area, it shows how well the finish retains it's shine when cleaned with an abrasive cleaner. Sticking- indicates the tendency for paints to not remain soft or tacky even when dry. Mildew- is the ability to inhibit mildew growth. FAding- reflects color change when exposed to UV light. Better one coat hiding- this one is VERY important to me, this indicates how well a paint covers in just one coat. Price- meaning the approximate price of one gallon of paint at retail cost.
They use some interesting criteria, but only about half of them truly apply to the professional IMO. The criteria based on abrasive cleaning and getting grease on the walls is out of our control IMO. I'm only worried about the things I can control. Most paints aren't designed for an "abrasive cleaner" IMO. I like SW 200 Eggshell products and feel like it certainly passes the look and durability tests within reason.
Old 08-05-2006, 06:58 PM   #10
...jammin
slickshift's Avatar
...they also are comparing what I would call wall paint against what I would call trim paint, w/o making any distinction between them
But still, I don't see how "needs-three-coats-to-still-look-bad" Behr anything can have "excellent hiding", and can score "excellent" in "sticking" when time everyone who's ever used it knows that stuff can take a week to dry
Signature Quote
Old 08-05-2006, 11:52 PM   #11
Teetorbilt's Avatar
I know where their exterior paint testing center is in So. FL. Also know where SW's is, not too far away.
I can assure you that they all use diagnostic criteria that are close. The panels (in many colors) are placed on supports that face east and are angled at about 30*.
The sites may have moved around a bit but have been here since the '60's and many were old then. (old Ft. Laud. airport property) across from the Airport Drive-In. I just tossed that in for any OLD spring breakers.
Albert Einstein
Teetorbilt is offline
want to hear about a crazy collection???? scottstef Business 23 10-08-2007 08:38 AM
Dodge Reports input ButlerDesigns Business 3 03-23-2007 01:39 PM
Home Inspection check list Shanklesbuilder General Discussion 8 09-06-2006 10:29 AM
Spell Check for Firefox Users Nathan General Discussion 17 03-07-2006 10:26 PM
