Changing Sheen On Varnished Trim
Old 05-07-2007, 02:10 PM   #1
Ogre's Avatar
Trade: Painting contractor
I am starting a job this week where the customer wants the trim varnished a different sheen. The trim is in good shape and is varnished to a semi maybe even a gloss. Should I sand like I would between coats or should I use a deglosser or both. I will be using a satin or low luster to recoat. Thanks Mike
Ogre is offline
Old 05-07-2007, 02:21 PM   #2
painterofeverything
painterofeveryt's Avatar
Trade: residential painter
Send a message via Yahoo to painterofeveryt
Re: Changing Sheen On Varnished Trim
I would sand it with 320 or so,dust or vacuum and apply the new varnish.
painterofeveryt is offline
Old 05-07-2007, 02:28 PM   #3
My custom title
Brushslingers's Avatar
yupyup, I agree.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-07-2007, 03:27 PM   #4
Estimator
DavidNTX's Avatar
Trade: Estimating
Deglosser can lift fresh paint or varnish.
DavidNTX is offline
Old School Trim ??? mobjack68 Finish Carpentry 27 09-17-2008 06:26 PM
Trim out of order, need some advice PaulG Painting & Finish Work 8 03-02-2007 03:49 AM
Glossy Trim jimbo123 Painting & Finish Work 5 02-06-2007 06:46 PM
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 13 08-25-2006 08:49 AM
