11-18-2008, 04:13 PM
#1
Trade:
commercial building restoration
Chain Link Fence Painting - Material???
ok, i have been having some trouble specifying a material to paint chain link fence. I don't need to know an application method.
I just need a material that has the following:
1) single component
2) dry in a reasonable amount of time
3) stick to galvanized chain link
4) Be a rust inhibitor
5) be less than $30.00 per gallon
6) single coat coverage
7) not silverbrite
8) meet the Ohio VOC regulations for 2009
An estimator that works with me lost a job because a SW rep told him one thing and an ICI rep told him the exact opposite. You look stupid if you change your spec after the quote is submitted.
I have painted miles of fencing and dont want to use ICI Devguard 4308-9020 again. its getting too pricy. Plus with the new VOC regulations in Ohio I dont even think that the 4308 will be sold anymore.
any help would be appriciated.
11-18-2008, 08:40 PM
#2
SANDBLASTING & REMODELING
Trade:
SODA BLASTING & REMODELING
well... what can i say.. rustoleum silver. although i dont use them for other things, I been using them on radiators for years.
11-19-2008, 07:02 AM
#3
Sarcastic Prick
Trade:
Paint and Floor Covering Retailer
I could get just what you need but I'm in Virginia and the company that makes it is a local Virginia company. I'm not sure if I could get them to ship to you. Depend on the quantity you need. Davis Frost just started making a brilliant aluminum paint based out of their acrylic DTM formulation. It'll stick to galvanized metal fine, it's low VOC (I'd have to check on your exact VOC regulations), dries fast, and does have some rust inhibitive properties. This is designed as an acrylic roof paint. The original product it was based on is designed for appliaction to rail cars. It's tough stuff. I'd have to check pricing on it but based on the DTM I sell, I'm sure I could get it for you for under $30 a gallon. The main problem is, that there aren't likely to be any dealers for this brand in your area. I could check and see who it closest to you if you want to avoid ordering the product and having it shipped in. Let me know if you want more info on the product. I'll see if I can get a hold of a PDS sheet for you.
Edit:
I looked into. There are dealer in Ohio for this product but they all seem to be clustered around Cincinnati.
11-29-2008, 09:33 PM
#4
Trade:
Painting Contractor
SW DTM Wash Primer ,sprayone coat (will neutralize the galvy)
SW Industrial Enamel ,spray two coats
Get ready for alot of overspray and cover from head to toe.
I like the IE over DTM because of the low temp dry times.
12-01-2008, 08:19 AM
#5
Trade:
I am looking for a one step process. it would cost 3x as much as a product that can cover in a single application. Plus, the SW Industrial Enamel does not meet the new VOC regulations for Ohio in 2009.
12-01-2008, 06:02 PM
#6
Trade:
Painting Contractor
For less than $30 a gallon?  Let me know when you find it.
12-02-2008, 07:58 AM
#7
Trade:
I get Devflex, Metalatex, Industrial Enamel, All Surface Enamel, DTM all for under $30 but they don't inhibit rust.
i think i might try the acrylic silverbirte product that a guy suggested at the beginning of this post. But I still have to price it out.
12-02-2008, 08:23 AM
#8
General Contractor
Trade:
Construction Management
1) single component
7) not silverbrite
Do it on the weekend. That should solve most of the beaurocracy.
Your not painting the white house.
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
12-03-2008, 07:00 AM
#9
Sarcastic Prick
Trade:
I've gotten some tentative pricing on the Davis product. It isn't pretty. Will probalby run you mid 40s unless you have some serious quantity. That may change as they put it into full scale production. The binders and the sheer amount of aluminum paste this company uses in the product make it a bit pricier than their normal DTM.
12-03-2008, 07:59 AM
#10
Trade:
Painter
Try sw DTM primer finish. Rust inhibitive and should be able to get under $30. Pretty sure it fits in the new voc regulations.
12-04-2008, 07:47 PM
#11
Painting Contractor
Trade:
Painting
Spray a chain link fence??? YIKES!!! Thats not good... What a waste of product and time... AND what a mess...
I would look into Devoe Coatings also.....
12-05-2008, 07:46 PM
#12
Trade:
Painting Contractor
I take it you've never sprayed chain link before ...... get your weenie roller out for 5000 ft of fence???? Plus it gives you better coverage. Not a waste of product or time if you know how to price it correctly.
12-05-2008, 11:04 PM
#13
General Contractor
Trade:
Sometimes you get all types of home owner responses like that one . jokeraceaward!
610 457-9721
12-08-2008, 10:23 PM
#14
Trade:
Painting Contractor
? my response?
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
