Trade: painter
Ceiling Painting
Starting a job and would like to get couple of professional opinions.
Painting the ceiling in all rooms in a house that has no furniture in it. I thought maybe spraying the ceilings. My main concern is not having the streaks in the ceiling. Recommend a good ceiling paint. Someone told me the SW promar 200 white is good paint for ceiling. Thanks |
FLORIDA CRACKER
Re: Ceiling Painting
spray it!!
promar is what we use.. also SW A100 |
FLORIDA CRACKER
sorry not a100 thats for exterior ..we use classic 99
Painting Contractor
Spraying all depends on if the walls are being painted too... and if the floors need covering...outlet's.. tops of baseboard... cabinets... heaters... doors...stairs/railings... etc etc... if its "just" the ceilings... I would cut and roll... by the time you get done masking and protecting everything that cant get oversprayed...(A LOT of over spray falls to the floor when spraying)... you will have the ceilings almost complete...
Im not a fan of SW... I use Benjamin Moore & California's Ceiling White... Manor Hall... If you dont want "lines" make sure you have the right tip and pressure... and I would recommend to back roll... Last edited by JMGP; 11-21-2006 at 09:54 AM. |
Trade: painting
If ceilings are smooth you should backroll. Textured, I wouldn't worry about it.
#6 | |
Back from the dead...
Trade: Paperhanger/Painter
Re: Ceiling PaintingQuote:
Thom
...and, if the ceilings are "popcorn" you've got to spray. If you spray, mask, mask, then mask some more.
Don
Trade: Paint Contractor
But you pretty much have to drape everything anyway when you roll. We just tape 1.5 mil plastic to the crown, or walls next to the ceiling then pull it out to drape everything. For flat ceilings we spray heavy (Pro Mar 200) then backroll, for textured just spray. Don't know how many ceilings you're talking, but me and two guys can drape and spray alot of ceiling space in a day.
#9 | |
Pro Painter
I agree. Promar is what I use on all ceilings...unless it's a rental, then it gets master hide.
#10 | |
...jammin
Trade: Rock Disciple
Cut 'n' roll Muresco
Popcorn/textured/flat, doesn't matter
Signature Quote Quote:
painterofeverything
anyone else use sherwins C.H.B ? a really cheap flat covers great round 10.00 a gallon...
Trade: Painter
I don't use it personally, but have used it on others' jobs. It does what it says, Builds out high, as in a thick coating that dries nice and is easy to touch up, beyond that, it's definaltley produced with the contactor in mind.
I've painted over it before and found it to be an unpredictable base coat. |
Personally I like to use the same paint that Michealangello used on the Cistene Chapel...
Mike Danahy
Trade: Signature Painter
Cut and roll Muresco... However if it's "Dune White"? then you're doing two coats for sure - doh!....
Not to complain about BM's colour or anything, but I'm not impressed. |
#15 | ||
...jammin
Didn't know that I just use ceiling white It's great
Mike Danahy
It was ceiling white tinted to the colour cc70 or Dune white. That was the trim colour, so the designer got the bright idea of convincing the HO that the ceiling should be the same...
Trade: Painter
200 is a good choice. For $12 a gallon I think it's great. However to those who say no need to backroll when spraying, I'd still give it a good look over the next day. I've noticed it likes to crack up sometimes without a backroll.
If you're only doing ceilings, cut & roll would probably be alot faster. It's flat so it's pretty easy to get a smooth finish. An 18" will make it even easier. |
#18 |
Professional Painter
Trade: Owner/Operator
Cut and roll it--it's faster and easier in an occupied home
...or does 'no furniture' mean new construction? Muresco or Masterhide are what I usually use
Rich Last edited by Richard; 11-22-2006 at 06:28 AM. |
#19 | ||
...jammin
Well thanks for the heads up I'll remember to "Just Say to Dune White Muresco"Same color as the trim huh? Okey Dokey
#20 |
Trade: painter
GLK...do you really get promar 200 for $12.00 a gallon...wow. Thats a great price from everything I have seen.
| Painting popcorn ceiling | rocco | Painting & Finish Work | 14 | 08-01-2007 10:52 PM |
| textured ceiling painting | NSolano | Painting & Finish Work | 8 | 02-21-2007 12:46 AM |
| Painting popcorn ceiling | navco1390 | Painting & Finish Work | 4 | 07-06-2006 07:43 PM |
| Painting in a tight stairway - some tips of the trade | Zeebo | Painting & Finish Work | 7 | 03-11-2006 08:49 AM |
