Old 05-19-2006, 01:46 PM   #1
Trade: painter
cedar deck
I was wondering how long you should wait before you stain (semi tranparent) a cedar deck? Is there a "rule of thumb" how long it takes the cedar to dry out? How about treated wood? Thanks
Alkyd is offline   Reply With Quote
Old 05-19-2006, 02:12 PM   #2
Trade: Paint and wallpaper
Alkyd, pick up a moisture meter. It will tell you what you need to know. As far as general rules with pressure treated woods, i've always heard 6 months, but if the moisture meter says its ok, then i'll paint it.
phinsher is offline   Reply With Quote
Old 05-19-2006, 07:40 PM   #3
Dan
ApgarNJ's Avatar
Trade: Residential Builder
Send a message via AIM to ApgarNJ
with pressure treated woods these days. if you wait 6 months, the deck is half worn by then. lol. i try not to use any PT wood for decks, other than framing. i use dry material and try to get my painter to stain them asap. the last few hardwood decks i have done. we have had the wood prestained onsite, all four sides, before we even start to work with it. that is recommended by most decking manufacturers, sealing just the top isn't doing the best job. all the sides and ends need to be sealed.
ApgarNJ is offline   Reply With Quote
Old 05-20-2006, 09:44 PM   #4
Professional Painter
Richard's Avatar
Trade: Owner/Operator
I use a moisture meter and stain/paint when its dry enough....I've only heard about time restrictions when it comes to painting new plaster....good luck....stain away!
Richard is offline   Reply With Quote
Old 05-21-2006, 12:02 AM   #5
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Pressure treated lumber should be allowed to go through a few wet/dry cycles at least before staining to help dry out the PT chemicals. Test with a moisture meter, and apply your stain when it's below 12%....or try Wood Tux Wet.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
New Clear Cedar Deck Finish Question TRISTAN Painting & Finish Work 2 08-15-2007 08:00 AM
Using 3"x5" cedar plank decking for a deck. Youngberg Decks & Fencing 1 05-09-2007 11:59 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 04:31 PM
new cedar deck problem mickchipp Decks & Fencing 5 12-04-2006 11:23 AM
New Cedar deck, Best sealer? Steampiper Decks & Fencing 23 07-27-2006 09:35 AM
