Caulking White Trim
Old 08-15-2013, 01:43 PM   #1
Livin the dream...
Spencer's Avatar
Trade: Remodeling/Finish Carpentry
Rewards Points: 5,496
Caulking White Trim
How much do you guys caulk around white trim before final painting? Casing and base?
I have heard of guys running a very thin bead around everything to create a seamless transition. Didn't know if that was normal or not?
Spencer is offline
Old 08-15-2013, 01:46 PM   #2
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Caulking White Trim
What you describe is what we do.
Every crevice gets caulk.
CrpntrFrk is offline
The Following 6 Users Say Thank You to CrpntrFrk For This Useful Post:
dkillianjr (08-15-2013), TAHomeRepairs (08-16-2013), thom (08-15-2013), TiM Management (08-21-2013), TNTSERVICES (09-24-2013), ToolNut (08-18-2013)
Old 08-15-2013, 02:35 PM   #3
Fine Handcrafted Opinions
Bearded Wonder's Avatar
Trade: General
Rewards Points: 1,340
Every joint.
Bearded Wonder is offline
Old 08-15-2013, 03:23 PM   #4
VinylHanger's Avatar
Rewards Points: 7,544
Every joint, whether it is white or not. If you don't and there is one tiny bit of open line showing, it looks unfinished.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
TiM Management (08-21-2013), woodworkbykirk (08-16-2013)
Old 08-15-2013, 03:26 PM   #5
Livin the dream...
Spencer's Avatar
Dang, looks like I've got my work cut out for me...
Any particular caulk you're using? DAP kwik seal?
Spencer is offline
Old 08-15-2013, 03:27 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,696
As nuch as I hate it, I usually caluk all trim to wall intersections.
I prefer stained work, up and done.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 08-15-2013, 04:04 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
every joint? really?I don't do that,I try to paint fill as much as possible then caulk if i need to on the final coat.. but you know I can see how it would look more seamless
Tom Struble is offline
Old 08-15-2013, 04:11 PM   #8
I like Green things
Not every joint, unless a person sucks at trim work.
I do wall to trim, I hate doing it, but people always complain about their wavy walls when they want painted trim, never say a word when it is stained.
That is now why people who want painted trim pay more for it then stained work.
Warner Mill Works
Facebook
YouTube
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
SmallTownGuy (08-15-2013), Tom Struble (08-15-2013)
Old 08-15-2013, 04:48 PM   #9
Painter
camaroman2125's Avatar
Trade: Painter
Rewards Points: 506
We caulk everything before we even put on primer. Then we primer everything, sand and sweep
then go back and hit any voids that are still showing.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
camaroman2125 is offline
The Following 2 Users Say Thank You to camaroman2125 For This Useful Post:
Bearded Wonder (08-15-2013), dkillianjr (08-15-2013)
Old 08-15-2013, 06:18 PM   #10
dkillianjr's Avatar
Rewards Points: 2,464
I do the same as camaroman. Caulk everything!
dkillianjr is offline
Old 08-15-2013, 06:43 PM   #11
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,167
Yep, pretty much caulk every seam before painting.
I always prime first, then caulk. I think the caulk adheres better to the primer.
-Paul
PeckDrywallandPainting.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following 7 Users Say Thank You to Sir Mixalot For This Useful Post:
Californiadecks (08-16-2013), CrpntrFrk (08-15-2013), dkillianjr (08-15-2013), Doctor Handyman (08-16-2013), Lyt (09-29-2013), Rbnsb5 (08-16-2013), TNTSERVICES (09-24-2013)
Old 08-15-2013, 06:58 PM   #12
Trade: General
Seems like caulking some areas but not others would leave a sporadic looking job. It's pretty much standard on every trim job I've ever painted or had painted to caulk every joint. Some guys do it before prime, some after, but if I saw a painter just caulking the areas that "need it" I would throw a fit...
Old 08-15-2013, 07:10 PM   #13
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,250
I use Big Stretch pretty much exclusively.
Robie is online now
BlueRidgeGreen (08-15-2013)
Old 08-15-2013, 07:41 PM   #14
I like Green things
I have been using polyseamseal that my lumberyard stocks.
Warner Mill Works
Facebook
YouTube
Old 08-15-2013, 08:24 PM   #15
Trade: siding
Rewards Points: 20
eww I don't really like seeing it all caulked up..you loose a lot of trim definition..and you better make sure who you are throwing that fit at
moorewarner (08-27-2013)
Old 08-15-2013, 08:32 PM   #16
Trade: General
Depends on who's caulking. Should be a small enough bead that you don't lose any trim definition. And it better be fingered. I've seen guys throw on a nice tiny bead but not wipe it down with a finger, and that does look bad. I don't like caulking as a substitute for good craftsmanship either, which I have seen.
The Following User Says Thank You to Bearded Wonder For This Useful Post:
Tom Struble (08-16-2013)
Old 08-15-2013, 08:33 PM   #17
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,412
I am 50 / 50. If the trim is getting painted then I usually caulk the trim, but not always. Some jobs get it others don't, It just boils down to what I think will look the best.
What I avoid is leaving caulk unpainted. I won't caulk the trim if the trim is not getting painted as the caulk may discolor over time.
Robie - how long do you leave the Big Stretch to set up before painting over it? I always leave it at least overnight. It is great caulk.
Ohio painter is offline
Old 08-15-2013, 08:38 PM   #18
carpenter jr
Carpenter eyes's Avatar
Trade: how hard can it be?!
All trim thats painted gets caulking. If i install, i caulk too. Then i proceed to cover myself in it
i cut this thing 3 times and its still too short!!
Carpenter eyes is offline
Old 08-15-2013, 08:41 PM   #19
Robie's Avatar
Yup, I strive for overnight. Strive I said. If overnight is impossible, I'll put a fan on it or in the room and if I'm careful with the brush, can put a coat on after two hours.
I'm one of those guys that tapes before I caulk, so I'm really wiping most of it off before I paint. With tape, I don't mess up the walls or trim by wiping a lot. So, the little amount left to blend any gap dries pretty fast.
Robie is online now
Old 08-15-2013, 10:23 PM   #20
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,130
seems that Dap white caulk goes translucent lately
Anderson is offline
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
had to fire the trim carpenter mnjconstruction Finish Carpentry 38 04-22-2011 07:51 PM
