Caulking Hardie Siding - Painting & Finish Work - Contractor Talk
Old 06-14-2015, 07:57 AM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,450
On new Hardie siding that is to be painted, are you caulking the butt joints between planks?
I plan to caulk where Hardie planks meet against trim boards but have heard mixed opinions in caulking butt joints. The boards are tight against each other, I would understand where there is a gap.
I appreciate any direction to this, I plan to prime with Loxon and finish with two coats of Resilience.
I also wonder if it's necessary why wouldn't it be caulked during installation? Surely that would be better? I know - "that's the painter's job".
Thanks.
Ohio painter is offline
Old 06-14-2015, 08:10 AM   #2
Shellbuilder's Avatar
Trade: Shell building contractor
Rewards Points: 1,236
Re: Caulking Hardie Siding
Read the Hardie installation specs.......http://www.hardieinstallation.com
www.shelladditions.com
Shellbuilder is offline
Old 06-14-2015, 12:26 PM   #3
VinylHanger's Avatar
Rewards Points: 7,994
I have always caulked my own installs. If it leaks, it won't be the painter they call back. If I didn't have to caulk, I could save days on most installs.
Sent from my QTAQZ3 using Tapatalk
VinylHanger is offline
Old 06-14-2015, 02:37 PM   #4
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
I would paint the seams, for when the panel shrinks..
I also use counter flashing of the same color as the siding color..
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 06-14-2015, 03:29 PM   #5
avenge's Avatar
Rewards Points: 2,946
If the installers used flashing at the butt joints then you shouldn't caulk them, if there isn't a gap at the butt joints you shouldn't caulk them.
Caulking I consider part of the install and not left to the painter that may caulk butt joints that aren't supposed to be caulked. Or use the incorrect caulk.
avenge is offline
Old 06-14-2015, 04:14 PM   #6
slowsol's Avatar
Rewards Points: 2,234
We don't caulk butt joints unless they are non factory ends. Which we don't do. Flash properly, follow the install guidelines and let it ride.
-John
slowsol is offline
Old 06-14-2015, 04:54 PM   #7
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I've always found that caulked joints look like crap. Flash them with a piece of color matched flat stock (best) or 30 lb felt (2nd best).
Your Dreams won't work unless you do.
SamM is offline
Old 06-16-2015, 05:48 AM   #8
I appreciate all the comments, and thanks for the Hardie Link.
Underlayment for Hardie siding fikey Windows, Siding and Doors 7 01-08-2015 06:17 AM
james hardie fiber-cement 8 1/4 lap siding jfreakme Windows, Siding and Doors 5 05-07-2013 12:02 AM
Installing Hardie Plank siding UpNorth Windows, Siding and Doors 15 07-22-2011 07:18 AM
Priming new Hardie siding summithomeinc Painting & Finish Work 10 07-19-2011 11:10 AM
Vinyl Siding vs Hardie Plank B.H.I Windows, Siding and Doors 6 11-06-2009 10:37 PM
