Caulking Cracks On Stucco Is Extremely Noticable
hello guys, just wanted to see if you guys encounter the same problem when caulking cracks on the stucco of homes. Ive noticed that on homes with that orange peel type textured stucco which is fairly smooth when i caulk the cracks even after painting they become extremely noticable. It leaves a trail wherever the crack was sealed with caulking. I have tried several things to try to solve the problem, i have smoothed out the caulking with a brush and water, i have also used a wet rag i have even put two coats of paint and you can still tell wherever i caulked. I know that the problem is that wherever you caulk it changes the texture of the stucco, but is there a solution to this? if i leave the cracks as is then you can still tell because you see the crack, if i fix it by caulking them then the problem is solved because the crack is sealed but you can still see wherever the cracks were. Is this normal or is there a way to solve it?
#2 | |
Pro Painter
Re: Caulking Cracks On Stucco Is Extremely Noticable
That's pretty much what you get with stucco. It's going to crack all over the place eventually. I see a ton of it here in FL where it's almost all stucco in new construction now days. Unless you want to dig out the crack, patch it, and match the texture, then caulk is about all you can do.
Try to keep the caulk inside the crack only, and have none on the surface. Also, try a quality block filler as a primer coat after caulking, and then use a good stucco paint like Loxon that goes on real thick. I'm saying that because it seems part of the issue may be flashing causing your caulk to stand out, but I'm just guessing. You'll still have smoother areas where the caulk is but they won't be as noticable. Forgot to say, you should also think about caulking cracks in stucco twice. The first go round usually shrinks in a little and looks bad, but a second time and it'll look good. If it's more than 1/8" crack....caulk isn't going to look good under any circumstance.
yeah thats exactly what i am going to have to tell the owner. There really isn't much else i can do. I kept that caulking within the crack and smoothed out the edges real good. Unless she wants those areas retextured.
Thanks for the response man, it feels good to know that someone has had this same problem. |
Trade: c35
here is the proper way to caulk cracks in stucco. They do make a caulking with sand in it, apply it as you would normally and float it with a sponge float. For larger cracks that you can stick your fingers in see hows it's done in my you tube videos (i have about 100 of them) Type in stuccoplastering on you tube.
http://youtu.be/oqm0D_p_308 I have been a stucco contractor for about 30 years and know how to fix any crack properly no matter how sandy the finish is. Best wishes. Kirk giordano plastering |
#5 | |
Trade: Exteriors
Re: Caulking Cracks On Stucco Is Extremely NoticableQuote:
![]() You answered a 6 year old thread but I like your video.
Trade: c35
amazing these question continue to appear after all this time. I will read a bit more before I respond next time have a nice evening, kirk Giordano plastering
#7 | |
Trade: Exteriors
| The Following User Says Thank You to rock16 For This Useful Post: | kirk giordano (09-19-2011) |
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Wall to ceiling cracks in foyer | ATHC | Drywall | 9 | 06-10-2008 08:00 AM |
| Some questions about painting outside stucco?? | Zeebo | Painting & Finish Work | 10 | 09-20-2006 08:09 AM |
| repairing stucco ceilings and cracks | Zeebo | Painting & Finish Work | 10 | 12-21-2005 06:43 PM |
