04-08-2006, 10:31 PM
#1
Trade:
trim,paint,clean
caulking above baseboard
Any tricks to caulking above baseboard? I've seen it shrink and leave a groove, and hate when it ends up on the wall and I have to touch up.
04-08-2006, 11:36 PM
#2
Trade:
Wood working in spare time.
The way i caulked above baseboard was run the caulk then i went over it with a damp washrag and it looked perfect. But then i can't caulk worth a crap. Some people can I CAN'T.
04-09-2006, 07:45 AM
#3
Trade:
Carpenter
Let the wood acclimate (and shrink) more before 'installation', - - or at least before 'painting', - - use a more 'flexible' caulk, - - and 'blue tape' 1/16" to 1/8" above your 'baseboard-line' before caulking, - - then 'wet-finger' caulk, remove tape, and 'wet-finger' caulk again.
04-09-2006, 08:43 AM
#4
Trade:
Cabinetmaker
Also, if the gap is wide enough that you are getting shrinkage, you may want to use 2-3 applications.
"Don't tread on me"
04-09-2006, 11:50 AM
#5
Pro Painter
Trade:
Painting Contractor
All good suggestions....I'll add one more that helps. Get a caulk with some body to it. I find the runnier the caulk the more it shrinks, sags and cracks. I always use SW 1100A 55 year siliconized latex caulk. Cracking is also caused by not allowing the caulk to dry properly before paint because the two products dry at different rates.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
“Knowledge will forever govern ignorance; and a people who mean to be their own governors must arm themselves with the power which knowledge gives.” -James Madison
04-09-2006, 12:16 PM
#6
painterofeverything
Trade:
residential painter
question
Let the wood acclimate (and shrink) more before 'installation', - - or at least before 'painting', - - use a more 'flexible' caulk, - - and 'blue tape' 1/16" to 1/8" ..................why use blue tape ?
04-09-2006, 01:20 PM
#7
Trade:
Carpenter
Just a method for those who may not be as 'experienced' in caulking, - - not saying who is or isn't, - - I can't really tell from here.
The blue tape will keep the wall clean from 'too much (accidental) caulk' SPREADING.
Sounded from her question like she's having a problem with the caulk 'overshooting' it's intended area, - - and 'carrying' onto more of the painted area than desired.
04-09-2006, 01:34 PM
#8
painterofeverything
Trade:
residential painter
ok, makes sense now that I understand where you wanted the tape,I thought you wanted it on the base...oops ! Thanks !
04-09-2006, 01:56 PM
#9
Trade:
Painting
I would say that if somebody has to use blue tape to caulk, they should just work on correcting their caulk overshooting problem instead. When you have a 2500 square foot house filled with base to caulk or something, that's a lot of tape and that stuff ain't cheap! What I do is cut a hole in the caulk tube that is the smallest hole possible...if you poke it with that pokey thing on the caulk gun, that hole is too big. Anyway, these days caulk doesn't really need to be poked or pierced...it comes out on its own with no problems. Too much water applied with the caulk may be a reason the caulk ends up looking concave going into the gap instead of bridging the gap. This is why a moist finger is best instead of using a sopping wet sponge or rag...you don't want to fill a gap with caulk and then wipe it all away.
04-09-2006, 03:05 PM
#10
Trade:
Carpenter
No argument there, Carl.
04-15-2006, 09:53 PM
#11
Trade:
Painting / Decorative Concrete
TOP GUN 2000
04-16-2006, 08:55 PM
#12
...jammin
Trade:
Rock Disciple
Originally Posted by Guardi Pro
TOP GUN 2000
Radio-controlled aircraft?
Tom Cruise movie re-make?
04-16-2006, 09:02 PM
#13
MODERATOR
Trade:
Paperhanger/Painter
Not sure about the flick, but I use/highly endorse Top Gun 200 caulk.
Distributed around here by Porter Paints, i assume its made by Pittsburgh/PPG Indus.
04-16-2006, 09:19 PM
#14
...jammin
Trade:
Rock Disciple
Originally Posted by ProWallGuy
...I use/highly endorse Top Gun 200 caulk.
Two Hundred?
Hmmm....no Porter paints here
Though the Mid-Cape Home Centers has Pittsburg (I haven't had the need for it up here, but I love their Speed-Hide Primer Sealer for new drywall  )
I'll check it out for "Top Gun 200"
Thanks GP and PWG
04-17-2006, 06:57 AM
#15
Trade:
Remodeling Contractor
I agree that the brand makes a big difference, I have found that the cheap "DAP" is too watery. I use Phenoseal, it is much thicker than most
04-17-2006, 08:32 AM
#16
Professional Remodeler
Trade:
I also like thicker caulk, it is easier to work with and doesn't shrink as much when it drys. I generally use PolySeamSeal. I hate Dap and the other "runny" caulks, they make more of a mess.
04-17-2006, 12:45 PM
#17
Trade:
Painting
Caulk Smoother
The Caulkrite tool is good for a nice clean caulk line. Can't get it in the UK at the moment, the one I've got has nearly had its day
04-17-2006, 07:54 PM
#18
Trade:
1 to many 0's... Top Gun 200, and Pro wall you are correct it's by PPG. Thanks for the correction
04-17-2006, 09:33 PM
#19
The Home Customizer
Trade:
CARPENTER
Just throwing this out there but Howmany of you caulk and putty your own trim when working for a GC. I under stand for a H/O but when I sub just the trim for a project I dont include caulk or putty. I would say that better that half of the trimmers in my area are the same way.
04-17-2006, 10:01 PM
#20
Painter
Trade:
Painter
After I blow out a house My dad will come in and do the finish (Dad was a finish carpenter for 25 years then went into Building). After he gets all the trim in I come behind him and fill all the holes. No caulk cause he uses a stain package.
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
