Trade: painter
Casement Window Stripping And Deck Wash
hey fellow painters I have a small project customer wants her anderson windows stripped down to bare and prime and paint it appears to have 3 coats of latex paint it now,any suggestions on strippers or sand it off?
same customer has a 8' x 10' cedar deck that has a red very spotty stain,owner wants stain removed and clear apply,powerwash and deckwash or is their a better way Thank you all for any suggestions any answers |
#2 | |
Pro Painter
Re: Casement Window Stripping And Deck Wash
Yes, there is a better way. What kind of finish is it? You'll need to strip the old finish before applying a new one. Depending on what the old finish looks like clear might not be the best option. Is it a solid stain that's on there now? Anyway, get a professional strength stripper and brightener/nuetralizer. Apply the stripper, let dwell (and keep wet) for 15 mins. Pressure wash (I say the term lightly) with 800-1200 psi MAX, nothing more or you'll be digging into the wood way too much. If it comes up, you're in good shape, if not, it will take multiple applications of the stripper, which is not cheap. You'll need to do a test before placing a bid on this job though. If it takes two or three applications to strip the old finish your costs will be much higher. Once you've stripped it rinse, rinse, and rinse some more. Then apply the brightener....it's a vital step. The brighteners, which are usually citric or oxacilic acid, nuetralize the caustic stripper. Let that dwell for 15 mins at least and then rinse, rinse, and rinse again for good measure. You'll want to at least wear rubber boots (stripper makes decks SLIPPPPERY), goggles, a respirator while applying chemicals, and some rubber gloves. (anything overhead requires a good full body rainsuit) The chemicals are serious business, you'll need to protect all plants nearby, and protect yourself. Keep the stripper off painted surfaces you don't want stripped, or at least wet those areas and keep them wet with water while stripping, it will remove paint.
There is so much more I could tell you. Wood restoration is fun stuff, but not something to take lightly. Just power washing with a ton of pressure and bleach is not the way to go, like a lot of people tend to do. They wash it down with bleach and stain over the old stuff. Here's a couple places to go for stripper, brighteners, and wood care in general. http://www.deckguide.com and http://www.sunbritesupply.com
#3 | |||
...jammin
Trade: Rock Disciple
Re: Casement Window Stripping And Deck WashQuote:
With those panes and all Yeeeeeeeaahh....that's going to be a joy Of course I'm picturing old moldy deteriorating ones, maybe it wont be so bad I don't care for chemicals I'd probably do it by hand If it was a lot I'd probably go UV Quote:
![]() ![]() ![]() You could probably go from stripper to brightener and skip the cleaner depending on how it comes out But the stripper does have to be neutralized before staining, and I like to "brighten" before applying any light stains anyway I apply with a hand sprayer and power wash off
Signature Quote Quote:
Trade: painter
cabots worked great on the deck,still trying to find the right stripper for the windows ,tried bixs didn't work as the salesman at sw said ,got a refund,bought strpyeze have'nt tried it yet hope its a winner,sorry for the delay in my reply got busy,thanks again for all the help
#5 | |
Pro Painter
Dad's paint stripper. I don't know the exact name, but dad's makes a stripper that works real good.
Painting Contractor
Try this to strip the windows....
http://www.ready-strip.com/Pages/readystripPRO-PD.html Your customer will love that it is inviromentally freindly... I use it all the time and it works great!!! (It spray's good too with the right sprayer and tip) Apply it and let it set over night... Make sure it is the pro version or higher... the standard Ready Strip (green) dont work as well... go to www.readystrip.com to look at other options... My paint suppliers stock it... I think Home Depot does to.... |
#7 | |
Pro Painter
Hey JGMP, I've heard good things about ready strip, but I haven't had a chance to use it....I think I'm going to try that out next time around!
| Exterior deck | mjay | Painting & Finish Work | 22 | 06-09-2007 11:52 PM |
| Stripping old deck finish | joedonuts | Painting & Finish Work | 26 | 06-09-2007 11:34 PM |
| Stripping Behr Sillycone Part Deaux | BDA4Life | Painting & Finish Work Picture Post | 16 | 04-19-2007 08:39 PM |
| warranty for painting a deck in chicago | gjs | Painting & Finish Work | 6 | 06-09-2006 07:28 AM |
