Can I Spray Shellac Primer Through My Airless
Old 01-22-2008, 08:08 PM   #1
sdmike1982's Avatar
Trade: painter
Im going to spray all the woodwork for an interior job. Since in spraying the finish coat, whats the point in rolling the shellac on. i got the epx2155 spraytech. If someone has experience with this i would greatly apprieciate some feedback. thanx
sdmike1982 is offline
Old 01-22-2008, 08:23 PM   #2
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
Re: Can I Spray Shellac Primer Through My Airless
Hmmm...I'm not Mr. Spray Shellac by any measure, but you can cut a 3lb shellac (like Zinsser's) down to 2lbs by mixing two parts denatured alcohol to 5 parts shellac
Usually it can then be sprayed with an airless using a .011 to .013 tip @ 800 - 1000 lbs
Signature Quote
slickshift is offline
Old 01-22-2008, 08:31 PM   #3
DeanV's Avatar
Trade: Painter
Rewards Points: 570
Are you talking BIN shellac or clear shellac? What was your airless used for before, and what type of top coat are you using?
If you put clear shellac through a latex pump and want a clear topcoat, I would be worried about the alcohol dissolving paint in the hoses and having flecks in the finish.
DeanV is online now
Old 01-23-2008, 11:27 AM   #4
UK airless user (v.rare!)
PowerPaintingUK's Avatar
Trade: Painting contractor
Rewards Points: 75
Not sure I'd want to put shellac through my rig I don't think the clean up would be much fun either(or even successful)
PowerPaintingUK is offline
Old 01-23-2008, 07:50 PM   #5
nick@nite
THINKPAINTING's Avatar
You can spray Binz with no problem, no need to cut it............works excellent on WW and sands fine.
THINKPAINTING is offline
Old 01-25-2008, 12:39 PM   #6
premierpainter's Avatar
Trade: Painting Contractor
Rewards Points: 250
I don't know about "Binz" but BIN makes for a very hard clean-up. I would never run it through my sprayers
premierpainter is offline
Old 01-25-2008, 08:23 PM   #7
nick@nite
Sorry but thats what we refer to bin as came from my old man many moons ago. We have absolutley no problem spraying BINZ through an airless
we just finished a 10,800 sq ft church ceiling, primed with BINZ and finished with an oil flat hand tinted off white, all by legal American Workers.
Same pump sprayed both with no problems, Graco pump about 15 yrs old.
O yeah, almost forgot all woodwork and cabinets were sprayed with BINZ and finished with SW Industrial Enamel semi gloss.
Can I spray a bed liner with my airless? KJLinden2002 Specialty Coatings 4 11-24-2008 06:40 PM
How do you spray a room - new construction? Zeebo Painting & Finish Work 16 01-27-2008 10:32 AM
Primer questions rebar17 Painting & Finish Work 14 10-25-2007 08:51 PM
spray shellac (tips please) painterofeveryt Painting & Finish Work 10 04-19-2007 09:15 PM
Help with my painting process + Airless Spray. Phouvieng Painting & Finish Work 10 07-09-2005 12:58 AM
