Can I Put A Clear Coat Over Paint?
Has anyone ever put clear coat over laytex paint. I am making a mailbox and would like it to last a long time any suggestions. I painted it with a good latex paint.
Re: Can I Put A Clear Coat Over Paint?
I wouldn't, clear coats are usually aggressive formulas that might cause the latex to lift, craze or bubble. You might want to think about an automotive paint system for longevity.
I like Green things
Use a deep base or accent base, varies from manufacturerer to manufactuerer, without any tint in it, it will dry clear, you need to thin the paint down a bit.
Trade: Painting Contractor
Use a high grade exterior acrylic for color retention. (factory ready mixed if possible) The best would be a 2-part Urethane. A clear coat may not do what you want.
Trade: painting contractor(semi retired)
Minwax polycrylic should work I believe. Just read the can. Not positive how it will hold up to weather ,but I've used it on doors and decorative wall indoors. pd
what about those glaze in faux finishes?
Trade: Home Improvement/Remodeling
I repainted a set of interior cabinets about 6 years ago and put a semi-gloss Polycrylic finish on it. I scuffed the paint before I put it on. It's held up great so far, but again, it's interior. Not sure how that combo would hold up to weathering.
I spent most of my money on booze and women. The rest I just wasted. www.forwardsolutions.net |
dont put a clear over exterior paint. The clear will wear out in a couple years and you'll be re-doing it. Go to your local PPG store and buy Pittsburgh Paints Manor Hall Gloss / Semi-Gloss Exterior. Great paint and it's very, very durable and washable. Manor hall semi and full gloss are interior / exterior rated. I painted some trim on my home with it and I hit it with the PW every spring and not so much as a flake.
Trade: faux painter/painter, general construction
I know this is 3-4yrs after you asked the question but I've used polycrylic over outdoor art on doors and mailboxes with nice results both in Florida and Wyoming. The paint I used was acrylic artist paints and faux glazes. Latex? That, I haven't done but you may as well try it. I don't think it will cause the paint to fail but just in case, try a sample piece and leave it outside for a while.
Trade: Wood n' concrete finishes
Polycrylic works except it has no UV protection in it...Exterior water-based poly should be fine. Right, 4 years later...so helpful...
| The Following User Says Thank You to Miss Brown For This Useful Post: | Jason@API (01-07-2012) |
Trade: Residential Painting Contractor
A HO asked me to put a clear coat on an existing mural that was painted on the side of her garage. With some research, I came up with ArborCoat Clear by Benjamin Moore. So far so good.
Newberg House Painter / Twitter / Facebook / Merchant Circle Please do not contact by phone or email for solicitation. |
#12 | |
Trade: 1970028
Re: Can I Put A Clear Coat Over Paint?Quote:
| The Following User Says Thank You to Alertchief For This Useful Post: | Jason@API (01-07-2012) |
#13 | |
Welcome to CT neighbor.
#14 | |
Trade: 1970028
#15 | |
4 years later... I totally missed the OP date...
Trade: painting and cleaning
not a good idea
| Stucco Finish coat seperating from base coat? | mwcuff | Masonry | 9 | 08-16-2008 08:42 PM |
| 3 Coat Floor Paint | vans | Painting & Finish Work | 6 | 12-01-2007 11:44 PM |
| One coat paint? | Chris G | Painting & Finish Work | 27 | 01-30-2007 08:51 PM |
| Question about Epoxy clear top coat. | metomeya | Painting & Finish Work | 4 | 10-10-2006 09:26 PM |
| Roof paint | Teetorbilt | Roofing | 3 | 05-07-2004 05:47 PM |
